1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ca_create_subscription element count
To: [email protected]
Date: Fri, 28 Jan 2011 13:31:20 -0800 (PST)
If the count in ca_create_subscription is > 1 and the type is
DBR_TIME_STRING, is the event_handler_args.dbr->value set to an array of
strings?
Also, when I try to do a ca_create_subscription on the excas pv named
albert (1000 elements), I get from the SEVCHK:
CA.Client.Exception...............................................
    Warning: "The requested data transfer is greater than available memory
or EPICS_CA_MAX_ARRAY_BYTES"
    Context: "ca_create_subscription"
    Source File: ../ca_monitor.cpp line 163
    Current Time: Fri Jan 28 2011 13:23:19.178091145
However, if I run the included camonitor tool on albert, it works fine.
Would this be because I am requesting the subscription with the
DBR_TIME_STRING?
Thank you again for your time,
Patrick
RE: ca_create_subscription element count Jeff Hill
Prev: Setting BPTR Till Straumann
Next: Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Setting BPTR Andrew Johnson
Next: RE: ca_create_subscription element count Jeff Hill
