1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca_create_channel memory management
To: "Tim Mooney" <[email protected]>
Cc: [email protected]
Date: Fri, 28 Jan 2011 15:09:44 -0800 (PST)
So in the best case scenario, I could just call ca_clear_channel after I
free pUserPrivate? Is there a way to determine if the worst case scenario
exists? If it does, is there anyway to fix or avoid it?
> Yes.  I'm worried about monitor (and other) callbacks that are
> in transit while the channel is being cleared.
> However, in the cases in which I needed to worry about this there was
> a software layer between the decision to clear the channel and the
> actual call to ca_clear_channel().  It may be that channel access
> somehow claws back sent monitors when a channel is cleared, but that
> has never been my understanding of how it works.  If it does work that
> way, all that I would worry about is that you're freeing pUserPrivate
> before calling ca_clear_channel(), thus opening a tiny time window in
> which a race condition is possible.
> Tim
> From: [email protected]
> Sent: Friday, January 28, 2011 3:04:41 PM
> Do you mean calls to the monitor callback function that have occurred
> prior to calling ca_clear_channel, but that somehow have not been
> processed?
>> I thought that ca_clear_channel took care of that? From the ca reference
>> manual:
>> Clearing a channel does not cause its disconnect handler to be called,
>> but
>> clearing a channel does shutdown and reclaim any channel state change
>> event subscriptions (monitors) registered with the channel.
>> Thank you,
>> Patrick
>>> If your channel is doing any callbacks (e.g., you're monitoring it),
>>> you might have outstanding monitors at the time you decide to clear
>>> the channel.  You need to tell your callback routine to ignore any
>>> calls that come after you've called cleanup(), so it doesn't reference
>>> pUserPrivate after it's been freed.
>>> Tim
>>>> To: "Andrew Johnson" <[email protected]>
>>>> Sent: Friday, January 28, 2011 11:56:37 AM
>>>> So:
>>>> void cleanup(chid ChanID) {
>>>> void* pUserPrivate;
>>>> pUserPrivate = ca_puser(ChanID);
>>>> free(pUserPrivate);
>>>> ca_clear_channel(ChanID);
>>>> > Hi Patrick,
>>>> > On Friday 28 January 2011 11:10:29 [email protected]
>>>> > wrote:
>>>> >> If you allocate memory and send a pointer to it in the puser field
>>>> >> of
>>>> >> ca_create_channel, does it get freed when ca_clear_channel is
>>>> >> called, or
>>>> >> should I do that explicitly?
>>>> > There's no way the CA API could know whether it should do that or
>>>> > not, so
>>>> > it
>>>> > doesn't and it falls on you to do it yourself.
>>>> > - Andrew
>>>> > If a man is offered a fact which goes against his instincts, he will
>>>> > scrutinize it closely, and unless the evidence is overwhelming, he
>>>> > will
>>>> > refuse to believe it. If, on the other hand, he is offered something
>>>> > which affords a reason for acting in accordance to his instincts, he
>>>> > will accept it even on the slightest evidence. -- Bertrand Russell
>>> Tim Mooney ([email protected]) (630)252-5417
>>> Software Services Group (www.aps.anl.gov)
>>> Advanced Photon Source, Argonne National Lab
Re: ca_create_channel memory management Matthieu Bec
Re: ca_create_channel memory management Tim Mooney
Prev: Re: Setting BPTR Andrew Johnson
Next: Re: registrySetTableSize() unusable Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ca_create_channel memory management Tim Mooney
Next: Re: ca_create_channel memory management Matthieu Bec
