1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsEvent (posix implementation) bug ?
Date: Mon, 31 Jan 2011 10:48:48 -0800
Is EINTR possible if there's some third-party code that is catching signals?
Also -- what changes are making?  Are you switching  vxWorks and RTEMS epicsEvent and epicsMessageQueue to queue-by-priority?  Are you taking the wait queue out of the POSIX epicsMessageQueue?
On Jan 31, 2011, at 10:41 AM, Andrew Johnson wrote:
> Hi Till,
> Thanks for the explanation, that helped a lot, I'll make the changes.
> Has anybody ever seen any of these error messages generated:
>    pthread_mutex_lock returned EINTR. Violates SUSv3
>    pthread_cond_timedwait returned EINTR. Violates SUSv3
>    pthread_cond_wait returned EINTR. Violates SUSv3
> I'm considering removing the internal routines that check for and print those
> in the 3.15 series since I've never seen them myself or any reports of them on
> tech-talk, and I suspect none of our current OSs would return EINTR from those
> routines.
Eric Norum
[email protected]
Re: epicsEvent (posix implementation) bug ? Andrew Johnson
epicsEvent (posix implementation) bug ? Till Straumann
Re: epicsEvent (posix implementation) bug ? Till Straumann
Prev: Re: epicsEvent (posix implementation) bug ? Andrew Johnson
Next: Re: epicsEvent (posix implementation) bug ? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
