1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsEvent (posix implementation) bug ?
To: Till Straumann <[email protected]>
Cc: [email protected]
Date: Mon, 31 Jan 2011 12:41:27 -0600
Hi Till,
Thanks for the explanation, that helped a lot, I'll make the changes.
Has anybody ever seen any of these error messages generated:
    pthread_mutex_lock returned EINTR. Violates SUSv3
    pthread_cond_timedwait returned EINTR. Violates SUSv3
    pthread_cond_wait returned EINTR. Violates SUSv3
I'm considering removing the internal routines that check for and print those
in the 3.15 series since I've never seen them myself or any reports of them on
tech-talk, and I suspect none of our current OSs would return EINTR from those
routines.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: epicsEvent (posix implementation) bug ? Eric Norum
epicsEvent (posix implementation) bug ? Till Straumann
Re: epicsEvent (posix implementation) bug ? Andrew Johnson
Re: epicsEvent (posix implementation) bug ? Till Straumann
Prev: Re: ca_create_channel memory management Tim Mooney
Next: Re: epicsEvent (posix implementation) bug ? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsEvent (posix implementation) bug ? Till Straumann
