1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ip330ScanMode template question
Date: Mon, 31 Jan 2011 16:55:24 -0800
Hi EPICS community,
Has anybody tested the ip330ScanMode template to change the scan mode of a ip330? If so, could you share your substitutions file to create records using the ip330ScanMode.template? I've tested the ip330ScanMode template with the following substitutions file and it doesn't appear to work. When I run my system without this scanmode template, and initialize the ip330 for scan mode 3, the ip330 runs fine in the continuous mode. When I include the scan mode template, and set the scan mode to 3, the ip330 data only updates one time. I’m using ip330-2-6 with epics base 3-14-11.
# file ip330ScanMode.template
file "$(IP330)/ip330ScanMode.template"
pattern
{P, R, SCANMODE, PORT}
# SCANMODE = 3 for continuous, 4 for triggered
{21:D3:, ADC, 3, "b-ADC}
Jay Steele
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
Re: ip330ScanMode template question Andrew Johnson
Prev: Re: epicsEvent (posix implementation) bug ? Andrew Johnson
Next: Re: ip330ScanMode template question Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Motor driver for Parker Hannifin ACR series controllers? Mark Rivers
