1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ip330ScanMode template question
To: Jay Steele <[email protected]>
Cc: [email protected]
Date: Tue, 1 Feb 2011 09:45:47 -0600
Hello Jay,
This response may not solve your problem, but it might help: If this was a
direct copy/paste of your substitutions file it's missing a closing double-
quote for the PORT value.  I would generally recommend that you enclose all
non-numeric values inside either single or double quotes, as the set of
characters that can be used in string values without quoting them is slightly
obscure.
On Monday 31 January 2011 18:55:24 Jay Steele wrote:
> # file ip330ScanMode.template
> file "$(IP330)/ip330ScanMode.template"
> pattern
> {P, R, SCANMODE, PORT}
> # SCANMODE = 3 for continuous, 4 for triggered
> {21:D3:, ADC, 3, "b-ADC}
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
RE: ip330ScanMode template question Jay Steele
Prev: ip330ScanMode template question Jay Steele
Next: RE: ip330ScanMode template question Jay Steele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
