1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ip330ScanMode template question
Date: Tue, 1 Feb 2011 09:04:16 -0800
Apologies - yes proper usage of the quotes fixed the problem. I had previously tried the following template without success. Thanks, Andrew.
# file ip330ScanMode.template
file "$(IP330)/ip330ScanMode.template"
pattern
{P, R, SCANMODE, PORT}
# SCANMODE = 3 for continuous, 4 for triggered
{21:D3:, ADC, 3, b-ADC}
Cheers,
Jay Steele
Sent: Tuesday, February 01, 2011 7:45 AM
To: Jay Steele
Cc: [email protected]
Subject: Re: ip330ScanMode template question
Hello Jay,
This response may not solve your problem, but it might help: If this was a
direct copy/paste of your substitutions file it's missing a closing double-
quote for the PORT value.  I would generally recommend that you enclose all
non-numeric values inside either single or double quotes, as the set of
characters that can be used in string values without quoting them is slightly
obscure.
> pattern
> {21:D3:, ADC, 3, "b-ADC}
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
 The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed.  Any use of this email for any other purpose is prohibited.  If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
ip330ScanMode template question Jay Steele
Re: ip330ScanMode template question Andrew Johnson
Prev: Re: ip330ScanMode template question Andrew Johnson
Next: crosscompilation and installation of bin/lib emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
