1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: crosscompilation and installation of bin/lib
To: EPICS tech-talk <[email protected]>
Date: Tue, 1 Feb 2011 09:54:09 -0800
Hello,
I have been crosscompiling for arms on intel cpu some time now.
Each time I cross compile, only the host binaries are installed.
what about the target binaries/libraries?
I usually copy them manually.
Is there a way to force installation?
PS: My arm(s) are running linux and nfs mounted.
So the installation of the linux-x86_64 bins/libs are actually not useful.
When cross compiling are you FTP'ing bins/libs/dbs/... to target?
I believe that is the most common way to install the files.
But in my case, I would like to use NFS.
Emmanuel
Re: crosscompilation and installation of bin/lib Andrew Johnson
Prev: RE: ip330ScanMode template question Jay Steele
Next: Re: epicsEvent (posix implementation) bug ? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: crosscompilation and installation of bin/lib Andrew Johnson
