1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: crosscompilation and installation of bin/lib
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 1 Feb 2011 13:54:22 -0800
After reading your email, I remembered that I am setting INSTALL_BIN to
.../bin/${EPICS_HOST_ARCH}.
Should it be .../bin/${T_A} ?
On 13:59 Tue 01 Feb     , Andrew Johnson wrote:
> Hi Emmanuel,
> On Tuesday 01 February 2011 11:54:09 [email protected] wrote:
> > I have been crosscompiling for arms on intel cpu some time now.
> > Each time I cross compile, only the host binaries are installed.
> > what about the target binaries/libraries?
> How have you configured your build to cause the host binaries to get
> installed?  Please be explicit, listing the names of the files you've changed
> and the settings you've made in those files.
> It should be possible to do what you want if you configure it right.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
Emmanuel
crosscompilation and installation of bin/lib emmanuel_mayssat
Re: crosscompilation and installation of bin/lib Andrew Johnson
Prev: Re: crosscompilation and installation of bin/lib Andrew Johnson
Next: Re: crosscompilation and installation of bin/lib emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
