1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MVME3100 second Ethernet with RTEMS
To: EPICS Tech Talk <[email protected]>
Date: Wed, 2 Feb 2011 15:42:51 -0800
I'm interested in hearing from anyone with experience using the second ethernet port of the MVME3100 with EPICS/RTEMS.
How did you set up the RTEMS network configuration initialization?
How did you get the signals from the VMEbus P2 connector to an RJ-45 connector? Did you use the MVME721Rear Transition Module?
Eric Norum
[email protected]
Prev: calc doesn't appear to be working with MEDM for string expressions (Win32 Extension Version 1.40) Jay Steele
Next: RE: calc doesn't appear to be working with MEDM for string expressions(Win32 Extension Version 1.40) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: calc doesn't appear to be working with MEDM for string expressions (Win32 Extension Version 1.40) Tim Mooney
Next: USB-scopes, anyone? Benjamin Franksen
