1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: USB-scopes, anyone?
To: <[email protected]>
Date: Thu, 3 Feb 2011 13:32:30 +0100
We are interested in evaluating USB-scopes (rack-mounted, no front panel)
for continuous signal measurements, as these are a lot cheaper than regular
scopes (with display and front panel controls). However, it is unclear
whether remote access to such scopes necessarily means using proprietary
(vendor supplied) software under Windows. Ideally, we would like to have an
asyn driver for USB (or some more specific protocol over USB), and then use
stream device support on top of that. Failing that, we would have to explore
other possibilities, like running an IOC on a Windows machine with a special
device support that talks with some (proprietary) vendor library.
Has anyone already done something like that? If yes, which
manufacturers/devices are you using? Has anyone experience with programming
USB? Could the protocol be reverse engineered?
Cheers
Ben
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: USB-scopes, anyone? Richard Farnsworth
Re: USB-scopes, anyone? Steven M. Hartman
Re: USB-scopes, anyone? Bruce Hill
Prev: Re: time discontinuity detected Michael Abbott
Next: Re: USB-scopes, anyone? Richard Farnsworth
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MVME3100 second Ethernet with RTEMS Eric Norum
