1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USB-scopes, anyone?
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Thu, 3 Feb 2011 09:02:00 -0600 (CST)
At my previous light source we had cheap rack mounted, 'no front panel' Scopes, although they were Ethernet based. A vaguely decent API was provided for Windows and Linux too.
The problems we had were that they could not co-exist on a network with broadcast traffic - they were intended for standalone bench use. In order to make them work at all, we had to have special VLAN segments just for the CRAPscopes or BITCRAPscopes as I recall the physicists calling them (Real name suppressed for libel reasons).
They weren't that good as scopes either from all accounts. They are a lot cheaper for good reasons - I recommend you bench check the true bandwidth and sampling specifications before writing a lot of code.
Sorry this doesn't help directly, but here be dragons. P.M. me for more information
Cheers
Richard
----- Original Message -----
To: [email protected]
Sent: Thursday, February 3, 2011 6:32:30 AM
Subject: USB-scopes, anyone?
We are interested in evaluating USB-scopes (rack-mounted, no front panel)
for continuous signal measurements, as these are a lot cheaper than regular
scopes (with display and front panel controls). However, it is unclear
whether remote access to such scopes necessarily means using proprietary
(vendor supplied) software under Windows. Ideally, we would like to have an
asyn driver for USB (or some more specific protocol over USB), and then use
stream device support on top of that. Failing that, we would have to explore
other possibilities, like running an IOC on a Windows machine with a special
device support that talks with some (proprietary) vendor library.
Has anyone already done something like that? If yes, which
manufacturers/devices are you using? Has anyone experience with programming
USB? Could the protocol be reverse engineered?
Cheers
Ben
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Richard Farnsworth
Controls Group leader
Phone 2-7710
USB-scopes, anyone? Benjamin Franksen
Prev: USB-scopes, anyone? Benjamin Franksen
Next: Re: calc doesn't appear to be working with MEDM for string expressions (Win32 Extension Version 1.40) Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: USB-scopes, anyone? Steven M. Hartman
