1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: time discontinuity detected
To: "Carsten Winkler (HZB)" <[email protected]>
Cc: [email protected]
Date: Thu, 3 Feb 2011 11:15:36 +0000 (GMT)
We've seen something similar to this, but perhaps a bit different.
On Wed, 2 Feb 2011, Carsten Winkler (HZB) wrote:
> Epics time goes crazy if I run softIoc with Epics base 3.14.12 (with all
> official patches) in a virtual machine.
Our problem occurred with EPICS 3.14.11.
> I use following configuration:
>                       Hypervisor:   kvm
>                       Architecture: x86_64
>                       Guest:        Windows XP (32-bit)
Our system administrator tells me that Windows XP doesn't support time
paravirtualisation, and that in this case you can expect your time to be
all over the place.  Do you know what your host system was?
Our problem was a bit stranger, with both RHEL5 host and guest system, and
quite difficult to reproduce.  After some searching I've found a couple of
Red Hat bug reports that seem related:
	https://bugzilla.redhat.com/show_bug.cgi?id=531268
	https://bugzilla.redhat.com/show_bug.cgi?id=521517
However, we were running with the linked advisory updates already applied.
I've been digging around trying to find out more about this issue, and it
seems rather complicated.  Here are some more related links:
	http://serverfault.com/questions/132197/best-practice-for-system-clock-sync-on-kvm-host
	http://www.vmware.com/pdf/vmware_timekeeping.pdf
though, of course, vmware is nothing directly to do with the issue.
> All works fine if I use a single core VM.
That's *very* interesting to learn, didn't know that.  I'll find out how
many cores our VM was using.
We found that running generalTimeReport on the offending IOC would report
astronomical numbers of timing errors, and that the time as seen by the
system would glitch forward and back by an hour or more.  I didn't succeed
in demonstrating the problem with a smaller example, so your tiny example
below is rather nice.
I haven't tried reproducing the problem for a couple of months or so ...
would be interested to hear from anyone else with time keeping problems on
virtual servers, but for the time being my IOCs are running on real
hardware.
> But if I use two or more CPU cores Epics time does several funny actions.
> * I also get events with a new value but previous time stamp.
> * Timestamps are wrong and in the future.
> * I get the message: "currentTime::getCurrentTime(): 7623636.000000sec time
> discontinuity detected".
> I've logged a test variable, which increments value every second.
> record(ai, "demoHost:aiExample")
>     field(DESC, "Analog input")
>     field(INP, "demoHost:calcExample.VAL  NPP NNS")
>     field(EGU, "Counts")
>     field(HOPR, "10")
>     field(LOPR, "0")
>     field(HIHI, "8")
>     field(HIGH, "6")
>     field(LOW, "4")
>     field(LOLO, "2")
>     field(HHSV, "MAJOR")
>     field(HSV, "MINOR")
>     field(LSV, "MINOR")
>     field(LLSV, "MAJOR")
> record(calc, "demoHost:calcExample")
>     field(DESC, "Counter")
>     field(SCAN, "1 second")
>     field(FLNK, "demoHost:aiExample")
>     field(CALC, "(A<B)?(A+C):D")
>     field(INPA, "demoHost:calcExample.VAL  NPP NNS")
>     field(INPB, "9")
>     field(INPC, "1")
>     field(INPD, "0")
>     field(HOPR, "10")
>     field(LOPR, "0")
>     field(HIHI, "8")
>     field(HIGH, "6")
>     field(LOW, "4")
>     field(LOLO, "2")
>     field(HSV, "MINOR")
>     field(LSV, "MINOR")
> This is the log of "camonitor.exe":
> One second = 1 minute?!!!
> demoHost:aiExample             2011-02-02 11:04:02.893304 5
> demoHost:aiExample             2011-02-02 11:04:55.757528 6 HIGH MINOR
> demoHost:aiExample             2011-02-02 11:05:35.900993 7 HIGH MINOR
> demoHost:aiExample             2011-02-02 11:05:44.292108 8 HIHI MAJOR
> demoHost:aiExample             2011-02-02 11:06:10.091333 9 HIHI MAJOR
> demoHost:aiExample             2011-02-02 11:07:11.216996 0 LOLO MAJOR
> demoHost:aiExample             2011-02-02 11:08:16.242185 1 LOLO MAJOR
> demoHost:aiExample             2011-02-02 11:09:00.773516 2 LOLO MAJOR
> demoHost:aiExample             2011-02-02 11:09:43.136728 3 LOW MINOR
> demoHost:aiExample             2011-02-02 11:10:25.476922 4 LOW MINOR
> demoHost:aiExample             2011-02-02 11:11:32.704872 5
> Allways the same time stamp?!!!
> demoHost:aiExample             2011-02-02 12:58:24.858648 5
> demoHost:aiExample             2011-02-02 12:58:24.858648 6 HIGH MINOR
> demoHost:aiExample             2011-02-02 12:58:24.858648 7 HIGH MINOR
> demoHost:aiExample             2011-02-02 12:58:24.858648 8 HIHI MAJOR
> demoHost:aiExample             2011-02-02 12:58:24.858648 9 HIHI MAJOR
> demoHost:aiExample             2011-02-02 12:58:24.858648 0 LOLO MAJOR
> demoHost:aiExample             2011-02-02 12:58:24.858648 1 LOLO MAJOR
> demoHost:aiExample             2011-02-02 12:58:24.858648 2 LOLO MAJOR
> demoHost:aiExample             2011-02-02 12:58:24.858648 3 LOW MINOR
> demoHost:aiExample             2011-02-02 12:58:24.858648 4 LOW MINOR
> The error message
> demoHost:aiExample             2011-02-02 13:09:15.978653 0 LOLO MAJOR
> demoHost:aiExample             2011-02-02 13:09:15.978653 1 LOLO MAJOR
> demoHost:aiExample             2011-02-02 13:09:15.978653 2 LOLO MAJOR
> currentTime::getCurrentTime(): 7623636.000000 sec time discontinuity detected
> currentTime::getCurrentTime(): 250144975.000000 sec time discontinuity
> detected
> demoHost:aiExample             2011-02-02 13:09:15.978653 3 LOW MINOR
> currentTime::getCurrentTime(): 249700665.000000 sec time discontinuity
> detected
> demoHost:aiExample             2011-02-02 13:09:15.978653 4 LOW MINOR
> demoHost:aiExample             2011-02-02 13:09:15.978653 5
> demoHost:aiExample             2011-02-02 13:09:15.978653 6 HIGH MINOR
> currentTime::getCurrentTime(): 241047173.000000 sec time discontinuity
> detected
time discontinuity detected Carsten Winkler (HZB)
Prev: RE: calc doesn't appear to be working with MEDM for string expressions(Win32 Extension Version 1.40) Mark Rivers
Next: USB-scopes, anyone? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: time discontinuity detected Carsten Winkler (HZB)
Next: Re: time discontinuity detected Andrew Johnson
