1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: New widget not available in Boy palette of Control System Studio
To: ZYCHLA Emmanuel <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 10 Feb 2011 08:29:21 -0500
Hi:
On 2/10/11 03:43 , "ZYCHLA Emmanuel" <[email protected]> wrote:
> ... but when I copy the
> plugin in CSS
I assume your code is perfect and you're sure that you put the correct
statements into your plugin.xml to register your widget, but it still
doesn't show up.
Does the plugin actually get loaded?
In CSS (or any Eclipse RCP app for that matter), check the menu Help,
About..., "Installation Details" button, Plug-ins tab.
You can sort the list of plugins by name etc. by clicking on the table
headers.
Does your plugin show up in that list?
If your plugin doesn't show up, read
  http://sourceforge.net/apps/trac/cs-studio/wiki/UpdateRepository
especially the section "Use of dropins, direct plugin manipulations".
Kay
RE : New widget not available in Boy palette of Control System Studio JOONEKINDT Didier
RE: New widget not available in Boy palette of Control System Studio ZYCHLA Emmanuel
Prev: New widget not available in Boy palette of Control System Studio ZYCHLA Emmanuel
Next: RE : New widget not available in Boy palette of Control System Studio JOONEKINDT Didier
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
