1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: New widget not available in Boy palette of Control System Studio
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 10 Feb 2011 15:46:05 +0000
Hi Kay,
Thanks for your answer.
I can see my plugin in Eclipse but not in CSS?
I read the section "Use of dropins, direct plugin manipulations" (in http://sourceforge.net/apps/trac/cs-studio/wiki/UpdateRepository) and I tried to modify the config.ini file as explained but I still do not see my plugin !
I have a question regarding css installation for ITER project that I have (codac package): why is there 2 css folders and so 2 plugins?
[root@vmware-ezc css]# pwd
/opt/codac-2.0/css
[root@vmware-ezc css]# ll
total 56
drwxr-xr-x 5 root root  4096 Dec 22 12:14 alarm-configtool
drwxr-xr-x 5 root root  4096 Dec 22 12:11 alarm-server
drwxr-xr-x 5 root root  4096 Dec 22 12:13 archive-configtool
drwxr-xr-x 5 root root  4096 Dec 22 12:11 archive-engine
drwxr-xr-x 5 root root  4096 Dec 22 12:13 css
drwxr-xr-x 5 root root  4096 Dec 22 12:11 jms2rdb
drwxr-xr-x 5 root root  4096 Dec 22 12:11 jms-send
drwxr-xr-x 2 root root  4096 Dec 22 12:13 ldap
drwxr-xr-x 3 root root 12288 Feb  9 13:46 plugins
drwxr-xr-x 2 root root  4096 Dec 22 12:14 rdb
[root@vmware-ezc css]# ll css
total 404
drwxr-xr-x 2 root root   4096 Dec 22 12:13 about_files
-rw-r--r-- 1 root root    577 Dec  8 01:12 about.html
drwxr-xr-x 3 root root   4096 Feb 10 15:52 configuration
-rwxr-xr-x 1 root root  26949 Dec  8 01:12 css
-rw-r--r-- 1 root root    148 Dec  8 01:12 css.ini
-rwxr-xr-x 1 root root    112 Dec  8 01:12 css.sh
-rw-r--r-- 1 root root   2972 Dec  8 01:12 icon.xpm
-rwxr-xr-x 1 root root 332320 Dec  8 01:12 libcairo-swt.so
drwxr-xr-x 4 root root  20480 Feb 10 16:15 plugins
Under css/plugins folders there are links to plugins folder?
Is there any reasons for this?
For my plugin, I did the same, I make a link.
Regards
Emmanuel
-----Original Message-----
Sent: jeudi 10 février 2011 14:29
To: ZYCHLA Emmanuel; [email protected]
Subject: Re: New widget not available in Boy palette of Control System Studio
Hi:
On 2/10/11 03:43 , "ZYCHLA Emmanuel" <[email protected]> wrote:
> ... but when I copy the
> plugin in CSS
I assume your code is perfect and you're sure that you put the correct
statements into your plugin.xml to register your widget, but it still
doesn't show up.
Does the plugin actually get loaded?
In CSS (or any Eclipse RCP app for that matter), check the menu Help,
About..., "Installation Details" button, Plug-ins tab.
You can sort the list of plugins by name etc. by clicking on the table
headers.
Does your plugin show up in that list?
If your plugin doesn't show up, read
especially the section "Use of dropins, direct plugin manipulations".
Kay
Ce message et les pièces jointes sont confidentiels et réservés à l'usage exclusif de ses destinataires. Il peut également être protégé par le secret professionnel. Si vous recevez ce message par erreur, merci d'en avertir immédiatement l'expéditeur et de le détruire. L'intégrité du message ne pouvant être assurée sur Internet, la responsabilité du groupe Atos Origin ne pourra être recherchée quant au contenu de ce message. Bien que les meilleurs efforts soient faits pour maintenir cette transmission exempte de tout virus, l'expéditeur ne donne aucune garantie à cet égard et sa responsabilité ne saurait être recherchée pour tout dommage résultant d'un virus transmis.
This e-mail and the documents attached are confidential and intended solely for the addressee; it may also be privileged. If you receive this e-mail in error, please notify the sender immediately and destroy it. As its integrity cannot be secured on the Internet, the Atos Origin group liability cannot be triggered for the message content. Although the sender endeavours to maintain a computer virus-free network, the sender does not warrant that this transmission is virus-free and will not be liable for any damages resulting from any virus transmitted.
Re: New widget not available in Boy palette of Control System Studio Kasemir, Kay
New widget not available in Boy palette of Control System Studio ZYCHLA Emmanuel
Prev: RE : New widget not available in Boy palette of Control System Studio JOONEKINDT Didier
Next: Re: New widget not available in Boy palette of Control System Studio Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
