1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: New widget not available in Boy palette of Control System Studio
To: "Chen, Xihui" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 11 Feb 2011 08:26:38 +0000
Hi Chen,
Thanks for your answer.
In fact I do not have “dropins” folder? So I copied the jar file in the “plugins” directory but as you explained in your article this not the right way. So I created a “dropins” folder to copy my jar file.
Unfortunately it does not work also and I realized that I do not have in my CSS version the “org.eclipse.equinox.p2.reconciler.dropins” plugin as explained in the article mentioned by Kay (http://sourceforge.net/apps/trac/cs-studio/wiki/UpdateRepository).
So I will try to install the SNS CSS product instead of the ITER version.
Thanks for your help.
Regards
Emmanuel
     Emmanuel Zychla ,
     Atos Origin - Grenoble Technology and Project Center
     36, Chemin du Vieux Chêne - BP 104
     38243 MEYLAN CEDEX
     FRANCE
     Phone (Meylan) : +33 4 76 41 67 28 (direct line)
     Mobile : +33 6 88 38 97 82
     Fax   : +33 4 76 41 67 67
     mailto:[email protected]
Sent: jeudi 10 février 2011 17:29
To: ZYCHLA Emmanuel; [email protected]
Hi Emmanuel,
Did you copy the jar file to the “dropins” folder under CSS directory?
I copied your jar file to my CSS/dropins directory.  And then started CSS and found that your widget works great except the widget icon might be too large ;)
Xihui
Sent: Thursday, February 10, 2011 3:44 AM
To: [email protected]
Subject: New widget not available in Boy palette of Control System Studio
Hi
I tried to create a customized widget for Boy as explained in the following article from [email protected] :
http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio/raw-file/67d9d72bab0c/applications/plugins/org.csstudio.opibuilder/html/CreateWidgets.html
I successfully created the plugin in Eclipse (step 3.6) but when I copy the plugin in CSS, I do not see my “Simple Bar Graph” widget in the Palette widow of CSS (see the CSS screen shot in the DebugInfo zip file)?
I do not know what is the wrong in my plugin? I check that all required plugins (org.eclipse.ui;resolution, org.eclipse.core.runtime, org.csstudio.opibuilder) exist in the css/plugin folder.
I attached the jar file (org.csstudio.opibuilder.widgetExample.SimpleBarGraph_1.0.0.201102091335.jar) of my plugin generated with Eclipse in the DebugInfo zip file.
Thanks for any helps
Regards
Emmanuel
Ce message et les pièces jointes sont confidentiels et réservés à l'usage exclusif de ses destinataires. Il peut également être protégé par le secret professionnel. Si vous recevez ce message par erreur, merci d'en avertir immédiatement l'expéditeur et de le détruire. L'intégrité du message ne pouvant être assurée sur Internet, la responsabilité du groupe Atos Origin ne pourra être recherchée quant au contenu de ce message. Bien que les meilleurs efforts soient faits pour maintenir cette transmission exempte de tout virus, l'expéditeur ne donne aucune garantie à cet égard et sa responsabilité ne saurait être recherchée pour tout dommage résultant d'un virus transmis.
This e-mail and the documents attached are confidential and intended solely for the addressee; it may also be privileged. If you receive this e-mail in error, please notify the sender immediately and destroy it. As its integrity cannot be secured on the Internet, the Atos Origin group liability cannot be triggered for the message content. Although the sender endeavours to maintain a computer virus-free network, the sender does not warrant that this transmission is virus-free and will not be liable for any damages resulting from any virus transmitted.
New widget not available in Boy palette of Control System Studio ZYCHLA Emmanuel
RE: New widget not available in Boy palette of Control System Studio Chen, Xihui
Prev: Re: UML model of EPICS haquin
Next: RE: soft ioc runs into fatal exception (base-3.14.12) Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: New widget not available in Boy palette of Control System Studio Chen, Xihui
Next: USB4000 Szalata, Zenon M.
