1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: USB4000
To: David Beauregard <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 11 Feb 2011 11:09:08 -0800
Hi David,
Thank you for your reply.
Yes, please, send me your driver.
Presently we have one USB2000 device and are planning to purchase two USB4000 units.  We are also looking to get the Omnidriver package.  I also started looking at the “USB4000 Data Sheet” which describes a command set, so I am thinking that it might be possible to write an asyn device driver using that information, bypassing the Omnidriver.  Have you considered that?  At this point I have only glanced at the note, so I am not sure yet what can be done.
Thanks again,
Zen
Sent: Friday, February 11, 2011 9:49 AM
To: Szalata, Zenon M.; [email protected]
Hi Zenon,
I have developed epics support for the OceanOptics spectrometers here at the CLS and it is being used by a couple other labs.  So far I have used it with the USB4000 and the QE65000.  I can send you the driver I have put together, but it makes use of the Omnidriver package and you will have to buy that from OceanOptics.  The latest version of this driver that I have uses the Omnidriver 1-5, have you already bought this?
David
From: [email protected] [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: February-10-11 2:13 PM
To: [email protected]
Subject: USB4000
Here at SLAC we are using the Ocean Optics USB 4000 Spectrometer device.  Presently we only have their application for controlling it.  The users are rather unhappy with it and are asking for EPICS application.
Has anyone developed an EPICS driver for this device?
If so, could it be made available?
Thanks in advance,
Zen
USB4000 Szalata, Zenon M.
RE: USB4000 David Beauregard
Prev: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
Next: RE: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: USB4000 David Beauregard
Next: RE: USB4000 Geng, Zheqiao
