1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Installing EPICS on Windows machine
Date: Fri, 11 Feb 2011 14:38:37 -0600
Thanks for the help everyone. It turns out Janet was correct. My problem was caused by EPICS base bug #626848, and making the change that was suggested below allowed me to successfully build.
Sent: February-10-11 1:06 PM
To: Morgan Bradford
Subject: Re: Installing EPICS on Windows machine
If you are using GNU make 3.82, it look like your problem may be from EPICS base bug #626848.
Try making the following change to your configure/RULES_BUILD file.
Index: RULES_BUILD
RCS file: /usr/local/epicsmgr/cvsroot/epics/base/configure/RULES_BUILD,v
retrieving revision 1.88.2.25
diff -r1.88.2.25 RULES_BUILD
369c369
< $(INSTALL_SHRLIB)/lib%: lib%
> $(INSTALL_SHRLIBS): $(INSTALL_SHRLIB)/lib%: lib%
Morgan Bradford wrote:
I am trying to install EPICS base-3.14.9 on a windows 7 computer, and keep getting the following error:
Installing shared library ../../../lib/win32-x86-mingw/libCom.a
mkdir ../../../lib
mkdir ../../../lib/win32-x86-mingw
ln -s libCom.a ../../../lib/win32-x86-mingw/libCom.a
ln: creating symbolic link `../../../lib/win32-x86-mingw/libCom.a' to `libCom.a'
: No such file or directory
mingw32-make[3]: *** [../../../lib/win32-x86-mingw/libCom.a] Error 1
mingw32-make[3]: Leaving directory `c:/epics/base-3.14.9/src/libCom/O.win32-x86-
mingw'
mingw32-make[2]: *** [install.win32-x86-mingw] Error 2
mingw32-make[2]: Leaving directory `c:/epics/base-3.14.9/src/libCom'
mingw32-make[1]: *** [libCom.install] Error 2
mingw32-make[1]: Leaving directory `c:/epics/base-3.14.9/src'
mingw32-make: *** [src.install] Error 2
What I did was:
Downloaded baseR3.14.9
Installed the latest version of Perl (strawberry)
Installed the latest version of MinGW
Set CONFIG_SITE.win32-x86-mingw.Common:  PERL=c:/strawberry/perl/bin/perl.exe
cd c:\epics\base-3.14.9
set EPICS_HOST_ARCH=win32-x86-mingw
mingw32-make
Any ideas on how to get past this error?
Morgan
Installing EPICS on Windows machine Morgan Bradford
Prev: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams
Next: EpicsQt build errors for QCaDesignerPlugin Morgan Bradford
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Installing EPICS on Windows machine Jeff Hill
Next: New widget not available in Boy palette of Control System Studio ZYCHLA Emmanuel
