Hi Andrew,
Sent from my iPhone
On Feb 11, 2011, at 11:39, Andrew Johnson <[email protected]> wrote:
> On Friday 11 February 2011 13:17:22 Jeff Hill wrote:
>>> I have the following running under ...
>>> vxWorks 6.8:
>>> Intel Dual Core
>> You must be one of the first sites running EPICS on the new symmetric
>> multiprocessing (SMP) vxWorks!
> Ernest, if you have more than one core enabled I can _guarantee_ that your IOC
> is not going to run properly. Our vxWorks OSD code is not ready for SMP
I will look into turning off SMP
> operation yet, it needs someone to go through it with a fine tooth-comb, which
> might be a good Codeathon project for one of your guys.
>>> Must I throw the "-mlong" flag?
>>> I thought that was only for the PowerPC architecture.?
> It's not going to be as simple as that.
> Please try running the libCom test suite on this CPU first:
> cd "/path/to/epics/base"
> ld 0,0, "bin/vxWorks-xxx/vxTestHarness.munch"
> epicsRunLibComTests
> Any test failures in the results should give a few ideas of places that will
> need a closer look.
Sounds good
I will do that next :)
Cheers
Ernest
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it. If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence. -- Bertrand Russell
- Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
- RE: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Jeff Hill
- Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Andrew Johnson
RE: Installing EPICS on Windows machine Morgan Bradford
<2011>
2025
2026
<2011>
2025
2026
