1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12
Date: Fri, 11 Feb 2011 23:18:31 -0800
Andrew Johnson wrote:
On Friday 11 February 2011 13:17:22 Jeff Hill wrote:
I have the following running under ...
vxWorks 6.8:
Intel Dual Core
You must be one of the first sites running EPICS on the new symmetric
multiprocessing (SMP) vxWorks!
Ernest, if you have more than one core enabled I can _guarantee_ that your IOC is not going to run properly. Our vxWorks OSD code is not ready for SMP operation yet, it needs someone to go through it with a fine tooth-comb, which might be a good Codeathon project for one of your guys.
Must I throw the  "-mlong"  flag?
I thought that was only for the PowerPC architecture.?
It's not going to be as simple as that.
Please try running the libCom test suite on this CPU first:
    cd "/path/to/epics/base"
    ld 0,0, "bin/vxWorks-xxx/vxTestHarness.munch"
    epicsRunLibComTests
Any test failures in the results should give a few ideas of places that will need a closer look.
   EPICS Test Harness Results
Failing Program           Tests  Faults
epicsStdioTest              163       2
6 subtests skipped
Failed 1/24 test programs. 2/2000 subtests failed.
Programs=24, Tests=2000, 421 wallclock secs
All Tests Passed except:
***** epicsStdioTest *****
1..163
ok  1 - epicsSnprintf(size=1) = 46
ok  2 - buffer = ''
ok  3 - length = 0
ok  4 - epicsSnprintf(size=2) = 46
ok  5 - buffer = 'i'
ok  6 - length = 1
ok  7 - epicsSnprintf(size=3) = 46
ok  8 - buffer = 'in'
ok  9 - length = 2
ok 10 - epicsSnprintf(size=4) = 46
ok 11 - buffer = 'int'
ok 12 - length = 3
ok 13 - epicsSnprintf(size=5) = 46
ok 14 - buffer = 'int '
ok 15 - length = 4
ok 16 - epicsSnprintf(size=6) = 46
ok 17 - buffer = 'int 1'
ok 18 - length = 5
ok 19 - epicsSnprintf(size=7) = 46
ok 20 - buffer = 'int 12'
ok 21 - length = 6
ok 22 - epicsSnprintf(size=8) = 46
ok 23 - buffer = 'int 123'
ok 24 - length = 7
ok 25 - epicsSnprintf(size=9) = 46
ok 26 - buffer = 'int 1234'
ok 27 - length = 8
ok 28 - epicsSnprintf(size=10) = 46
ok 29 - buffer = 'int 1234 '
ok 30 - length = 9
ok 31 - epicsSnprintf(size=11) = 46
ok 32 - buffer = 'int 1234 f'
ok 33 - length = 10
ok 34 - epicsSnprintf(size=12) = 46
ok 35 - buffer = 'int 1234 fl'
ok 36 - length = 11
ok 37 - epicsSnprintf(size=13) = 46
ok 38 - buffer = 'int 1234 flo'
ok 39 - length = 12
ok 40 - epicsSnprintf(size=14) = 46
ok 41 - buffer = 'int 1234 floa'
ok 42 - length = 13
ok 43 - epicsSnprintf(size=15) = 46
ok 44 - buffer = 'int 1234 float'
ok 45 - length = 14
ok 46 - epicsSnprintf(size=16) = 46
ok 47 - buffer = 'int 1234 float '
ok 48 - length = 15
ok 49 - epicsSnprintf(size=17) = 46
ok 50 - buffer = 'int 1234 float 1'
ok 51 - length = 16
ok 52 - epicsSnprintf(size=18) = 46
ok 53 - buffer = 'int 1234 float 1.'
ok 54 - length = 17
ok 55 - epicsSnprintf(size=19) = 46
ok 56 - buffer = 'int 1234 float 1.2'
ok 57 - length = 18
ok 58 - epicsSnprintf(size=20) = 46
ok 59 - buffer = 'int 1234 float 1.23'
ok 60 - length = 19
ok 61 - epicsSnprintf(size=21) = 46
ok 62 - buffer = 'int 1234 float 1.23e'
ok 63 - length = 20
ok 64 - epicsSnprintf(size=22) = 46
ok 65 - buffer = 'int 1234 float 1.23e+'
ok 66 - length = 21
ok 67 - epicsSnprintf(size=23) = 46
ok 68 - buffer = 'int 1234 float 1.23e+0'
ok 69 - length = 22
ok 70 - epicsSnprintf(size=24) = 46
ok 71 - buffer = 'int 1234 float 1.23e+04'
ok 72 - length = 23
ok 73 - epicsSnprintf(size=25) = 46
ok 74 - buffer = 'int 1234 float 1.23e+04 '
ok 75 - length = 24
ok 76 - epicsSnprintf(size=26) = 46
ok 77 - buffer = 'int 1234 float 1.23e+04 s'
ok 78 - length = 25
ok 79 - epicsSnprintf(size=27) = 46
ok 80 - buffer = 'int 1234 float 1.23e+04 st'
ok 81 - length = 26
ok 82 - epicsSnprintf(size=28) = 46
ok 83 - buffer = 'int 1234 float 1.23e+04 str'
ok 84 - length = 27
ok 85 - epicsSnprintf(size=29) = 46
ok 86 - buffer = 'int 1234 float 1.23e+04 stri'
ok 87 - length = 28
ok 88 - epicsSnprintf(size=30) = 46
ok 89 - buffer = 'int 1234 float 1.23e+04 strin'
ok 90 - length = 29
ok 91 - epicsSnprintf(size=31) = 46
ok 92 - buffer = 'int 1234 float 1.23e+04 string'
ok 93 - length = 30
ok 94 - epicsSnprintf(size=32) = 46
ok 95 - buffer = 'int 1234 float 1.23e+04 string '
ok 96 - length = 31
ok 97 - epicsSnprintf(size=33) = 46
ok 98 - buffer = 'int 1234 float 1.23e+04 string O'
ok 99 - length = 32
ok 100 - epicsSnprintf(size=34) = 46
ok 101 - buffer = 'int 1234 float 1.23e+04 string On'
ok 102 - length = 33
ok 103 - epicsSnprintf(size=35) = 46
ok 104 - buffer = 'int 1234 float 1.23e+04 string One'
ok 105 - length = 34
ok 106 - epicsSnprintf(size=36) = 46
ok 107 - buffer = 'int 1234 float 1.23e+04 string OneT'
ok 108 - length = 35
ok 109 - epicsSnprintf(size=37) = 46
ok 110 - buffer = 'int 1234 float 1.23e+04 string OneTw'
ok 111 - length = 36
ok 112 - epicsSnprintf(size=38) = 46
ok 113 - buffer = 'int 1234 float 1.23e+04 string OneTwo'
ok 114 - length = 37
ok 115 - epicsSnprintf(size=39) = 46
ok 116 - buffer = 'int 1234 float 1.23e+04 string OneTwoT'
ok 117 - length = 38
ok 118 - epicsSnprintf(size=40) = 46
ok 119 - buffer = 'int 1234 float 1.23e+04 string OneTwoTh'
ok 120 - length = 39
ok 121 - epicsSnprintf(size=41) = 46
ok 122 - buffer = 'int 1234 float 1.23e+04 string OneTwoThr'
ok 123 - length = 40
ok 124 - epicsSnprintf(size=42) = 46
ok 125 - buffer = 'int 1234 float 1.23e+04 string OneTwoThre'
ok 126 - length = 41
ok 127 - epicsSnprintf(size=43) = 46
ok 128 - buffer = 'int 1234 float 1.23e+04 string OneTwoThree'
ok 129 - length = 42
ok 130 - epicsSnprintf(size=44) = 46
ok 131 - buffer = 'int 1234 float 1.23e+04 string OneTwoThreeF'
ok 132 - length = 43
ok 133 - epicsSnprintf(size=45) = 46
ok 134 - buffer = 'int 1234 float 1.23e+04 string OneTwoThreeFo'
ok 135 - length = 44
ok 136 - epicsSnprintf(size=46) = 46
ok 137 - buffer = 'int 1234 float 1.23e+04 string OneTwoThreeFou'
ok 138 - length = 45
ok 139 - epicsSnprintf(size=47) = 46
ok 140 - buffer = 'int 1234 float 1.23e+04 string OneTwoThreeFour'
ok 141 - length = 46
ok 142 - epicsSnprintf(size=48) = 46
ok 143 - buffer = 'int 1234 float 1.23e+04 string OneTwoThreeFour'
ok 144 - length = 46
ok 145 - epicsSnprintf(size=49) = 46
ok 146 - buffer = 'int 1234 float 1.23e+04 string OneTwoThreeFour'
ok 147 - length = 46
ok 148 - epicsSnprintf(size=50) = 46
ok 149 - buffer = 'int 1234 float 1.23e+04 string OneTwoThreeFour'
ok 150 - length = 46
ok 151 - epicsGetStdout() == stdout
ok 152 - (stream = fopen(report, "w")) != NULL
ok 153 - stdout == stream
ok 154 - epicsGetStdout() == realStdout
ok 155 - stdout == realStdout
not ok 156 - !fclose(stream)
# fclose error: S_netDrv_UNIX_FILE_ERROR
not ok 157 - (stream = fopen(report, "r")) != NULL
# 'report' could not be opened for reading: S_netDrv_UNIX_FILE_ERROR
ok 158 # SKIP Can't reopen stream file.
ok 159 # SKIP Can't reopen stream file.
ok 160 # SKIP Can't reopen stream file.
ok 161 # SKIP Can't reopen stream file.
ok 162 # SKIP Can't reopen stream file.
ok 163 # SKIP Can't reopen stream file.
   Results
      Tests: 163
     Passed: 161 = 98.77%
     Failed:   2 =  1.23%
    Skipped:   6 =  3.68%
- Andrew
Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
RE: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Jeff Hill
Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Andrew Johnson
Prev: Problem building EPICSQt ASgui Morgan Bradford
Next: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams
