1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12
Date: Sat, 12 Feb 2011 00:57:44 -0800
Hi Andrew,
My initial posting was about a new Pentium4 Dual Core IOC.
However, I was not running an SMP vxWorks Image.
So, my original problem must be related to a change in the memLib API from Windriver,
I will investigate that a bit more based on the information from Jeff.
Meanwhile, I decided to  go ahead and build a SMP vxWorks image.   :)
You are right, changes are definitely needed
I can't even run the libCom Tests since routines like "intLock" and "taskLock" are not available.
Now, we must use spinlocks and other atomic routines in the vxWorks SMP API
I agree an excellent codeathon activity :-)
Press any key to stop auto-boot...
1
auto-booting...
boot device          : gei
unit number          : 0
processor number     : 0
host name            : rsh
file name : /afs/slac/g/lcls/epics/iocCommon/ioc-b34-cd05/vxWorksV/vxWorks
inet on ethernet (e) : 134.79.219.51:fffffc00
host inet (h)        : 134.79.19.73
gateway inet (g)     : 134.79.219.1
user (u)             : cdvx
flags (f)            : 0x0
target name (tn)     : ioc-b34-cd05
startup script (s) : /afs/slac/g/lcls/epics/iocCommon/ioc-b34-cd05/startup.cmd
Loading... 1634768 + 276224
Starting at 0x408000...
Loading symbol table from rsh:/afs/slac/g/lcls/epics/iocCommon/ioc-b34-cd05/vxWorksV/vxWorke
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]]       Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]]       VxWorks 6.8 SMP
]]]]]]]]]]]]]]]]]]]]]]]]]]       KERNEL: WIND version 2.13
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-2009
CPU: GE Intelligent Platforms Embedded Systems - XVB601-BSP-VXW SMP - SYMMETRIC_IO_MODE. .
Memory Size: 0xcb6fa000.  BSP version 2.0/01.04.
Created: Feb 12 2011, 00:39:27
ED&R Policy Mode: Deployed
WDB Comm Type: WDB_COMM_END
WDB: Ready.
Executing startup script '/afs/slac/g/lcls/epics/iocCommon/ioc-b34-cd05/startup.cmd'...
# IOC Application Startup
# Execute the startup script for the IOC specific application
##cd "/afs/slac/g/lcls/epics/TestStand/iocTop/R3-14-12/performanceTest/Development/iocBoot/"
##< st.cmd
# Run the libCom Tests from EPICS BASE:
cd "/afs/slac/g/lcls/epics/base/base-R3-14-12"
value = 0 = 0x0
ld(0,0, "bin/vxWorks-pentium4/vxTestHarness.munch")
Warning: module 0xd4d643c holds reference to undefined symbol intUnlock.
Warning: module 0xd4d643c holds reference to undefined symbol intLock.
Warning: module 0xd4d643c holds reference to undefined symbol taskVarAdd.
Warning: module 0xd4d643c holds reference to undefined symbol taskVarDelete.
ld(): module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
Done executing startup script '/afs/slac/g/lcls/epics/iocCommon/ioc-b34-cd05/startup.cmd'.
ioc-b34-cd05>
Andrew Johnson wrote:
On Friday 11 February 2011 13:17:22 Jeff Hill wrote:
I have the following running under ...
vxWorks 6.8:
Intel Dual Core
You must be one of the first sites running EPICS on the new symmetric
multiprocessing (SMP) vxWorks!
Ernest, if you have more than one core enabled I can _guarantee_ that your IOC is not going to run properly. Our vxWorks OSD code is not ready for SMP operation yet, it needs someone to go through it with a fine tooth-comb, which might be a good Codeathon project for one of your guys.
Must I throw the  "-mlong"  flag?
I thought that was only for the PowerPC architecture.?
It's not going to be as simple as that.
Please try running the libCom test suite on this CPU first:
    cd "/path/to/epics/base"
    ld 0,0, "bin/vxWorks-xxx/vxTestHarness.munch"
    epicsRunLibComTests
Any test failures in the results should give a few ideas of places that will need a closer look.
- Andrew
Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Andrew Johnson
Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
RE: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Jeff Hill
Prev: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
Next: Atomtex radiation monitors Bryce Karnaghan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Andrew Johnson
