1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Atomtex radiation monitors
Date: Mon, 14 Feb 2011 11:55:24 +1100
Is anyone using any Atomtex radiation monitors? These devices have a modbus RTU implementation but the CRC bytes are reversed!!
Works o/k with their own windows applications as these also swap the CRC bytes.
Trying to convince Atomtex to fix this and looking to see if there is any other facilities that could support our case.
Regards
http://www.synchrotron.org.au/images/emails/logosig.gif
Bryce Karnaghan | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4135 | f: (03) 8540 4200 | m: 0423 844 592
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Prev: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
Next: Error vxi11 with Lecroy 760Zi DENIS Jean-françois
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem building EPICSQt ASgui Morgan Bradford
