1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem building EPICSQt ASgui
Date: Fri, 11 Feb 2011 17:30:43 -0600
I am trying to build ASgui.pro from the EPICSQt package on Windows, and I am getting the following build error and it’s not clear to me what the problem is.
Compile Output:
The process "C:/MinGW/bin/mingw32-make.exe" exited normally.
Configuration unchanged, skipping qmake step.
Starting: "C:/MinGW/bin/mingw32-make.exe" -w
mingw32-make: Entering directory `C:/Qt/2010.05/epicsqt/applications/ASguiApp'
C:/MinGW/bin/mingw32-make -f Makefile.Debug
mingw32-make[1]: Entering directory `C:/Qt/2010.05/epicsqt/applications/ASguiApp'
c:/Qt/2010.05/qt/bin/uic.exe src/MainWindow.ui -o ui_MainWindow.h
g++ -c -g -pg -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I'../../../qt/include/QtUiTools' -I'../../../qt/include/QtCore' -I'../../../qt/include/QtNetwork' -I'../../../qt/include/QtGui' -I'../../../qt/include/QtXml' -I'../../../qt/include' -I'.' -I'include' -I'../../ca_framework/data/include' -I'../../ca_framework/widgets/include' -I'../../ca_framework/plugins/include' -I'../../../qt/include/ActiveQt' -I'debug' -I'.' -I'../../../qt/mkspecs/win32-g++' -o debug/main.o src/main.cpp
g++ -c -g -pg -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I'../../../qt/include/QtUiTools' -I'../../../qt/include/QtCore' -I'../../../qt/include/QtNetwork' -I'../../../qt/include/QtGui' -I'../../../qt/include/QtXml' -I'../../../qt/include' -I'.' -I'include' -I'../../ca_framework/data/include' -I'../../ca_framework/widgets/include' -I'../../ca_framework/plugins/include' -I'../../../qt/include/ActiveQt' -I'debug' -I'.' -I'../../../qt/mkspecs/win32-g++' -o debug/MainWindow.o src/MainWindow.cpp
g++ -c -g -pg -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I'../../../qt/include/QtUiTools' -I'../../../qt/include/QtCore' -I'../../../qt/include/QtNetwork' -I'../../../qt/include/QtGui' -I'../../../qt/include/QtXml' -I'../../../qt/include' -I'.' -I'include' -I'../../ca_framework/data/include' -I'../../ca_framework/widgets/include' -I'../../ca_framework/plugins/include' -I'../../../qt/include/ActiveQt' -I'debug' -I'.' -I'../../../qt/mkspecs/win32-g++' -o debug/StartupParams.o src/StartupParams.cpp
g++ -c -g -pg -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I'../../../qt/include/QtUiTools' -I'../../../qt/include/QtCore' -I'../../../qt/include/QtNetwork' -I'../../../qt/include/QtGui' -I'../../../qt/include/QtXml' -I'../../../qt/include' -I'.' -I'include' -I'../../ca_framework/data/include' -I'../../ca_framework/widgets/include' -I'../../ca_framework/plugins/include' -I'../../../qt/include/ActiveQt' -I'debug' -I'.' -I'../../../qt/mkspecs/win32-g++' -o debug/InstanceManager.o src/InstanceManager.cpp
g++ -c -g -pg -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I'../../../qt/include/QtUiTools' -I'../../../qt/include/QtCore' -I'../../../qt/include/QtNetwork' -I'../../../qt/include/QtGui' -I'../../../qt/include/QtXml' -I'../../../qt/include' -I'.' -I'include' -I'../../ca_framework/data/include' -I'../../ca_framework/widgets/include' -I'../../ca_framework/plugins/include' -I'../../../qt/include/ActiveQt' -I'debug' -I'.' -I'../../../qt/mkspecs/win32-g++' -o debug/gdbmacros.o ../../../share/qtcreator/gdbmacros/gdbmacros.cpp
../../../share/qtcreator/gdbmacros/gdbmacros.cpp: In member function '<unnamed>::QDumper&<unnamed>::QDumper::put(long long unsigned int)':
../../../share/qtcreator/gdbmacros/gdbmacros.cpp:580:46: warning: unknown conversion type character 'l' in format
../../../share/qtcreator/gdbmacros/gdbmacros.cpp:580:46: warning: too many arguments for format
../../../share/qtcreator/gdbmacros/gdbmacros.cpp: In member function '<unnamed>::QDumper&<unnamed>::QDumper::put(long long int)':
../../../share/qtcreator/gdbmacros/gdbmacros.cpp:587:46: warning: unknown conversion type character 'l' in format
../../../share/qtcreator/gdbmacros/gdbmacros.cpp:587:46: warning: too many arguments for format
C:/Qt/2010.05/qt/bin/moc.exe -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I'../../../qt/include/QtUiTools' -I'../../../qt/include/QtCore' -I'../../../qt/include/QtNetwork' -I'../../../qt/include/QtGui' -I'../../../qt/include/QtXml' -I'../../../qt/include' -I'.' -I'include' -I'../../ca_framework/data/include' -I'../../ca_framework/widgets/include' -I'../../ca_framework/plugins/include' -I'../../../qt/include/ActiveQt' -I'debug' -I'.' -I'../../../qt/mkspecs/win32-g++' -D__GNUC__ -DWIN32 include/MainWindow.h -o debug/moc_MainWindow.cpp
g++ -c -g -pg -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I'../../../qt/include/QtUiTools' -I'../../../qt/include/QtCore' -I'../../../qt/include/QtNetwork' -I'../../../qt/include/QtGui' -I'../../../qt/include/QtXml' -I'../../../qt/include' -I'.' -I'include' -I'../../ca_framework/data/include' -I'../../ca_framework/widgets/include' -I'../../ca_framework/plugins/include' -I'../../../qt/include/ActiveQt' -I'debug' -I'.' -I'../../../qt/mkspecs/win32-g++' -o debug/moc_MainWindow.o debug/moc_MainWindow.cpp
C:/Qt/2010.05/qt/bin/moc.exe -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I'../../../qt/include/QtUiTools' -I'../../../qt/include/QtCore' -I'../../../qt/include/QtNetwork' -I'../../../qt/include/QtGui' -I'../../../qt/include/QtXml' -I'../../../qt/include' -I'.' -I'include' -I'../../ca_framework/data/include' -I'../../ca_framework/widgets/include' -I'../../ca_framework/plugins/include' -I'../../../qt/include/ActiveQt' -I'debug' -I'.' -I'../../../qt/mkspecs/win32-g++' -D__GNUC__ -DWIN32 include/InstanceManager.h -o debug/moc_InstanceManager.cpp
g++ -c -g -pg -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I'../../../qt/include/QtUiTools' -I'../../../qt/include/QtCore' -I'../../../qt/include/QtNetwork' -I'../../../qt/include/QtGui' -I'../../../qt/include/QtXml' -I'../../../qt/include' -I'.' -I'include' -I'../../ca_framework/data/include' -I'../../ca_framework/widgets/include' -I'../../ca_framework/plugins/include' -I'../../../qt/include/ActiveQt' -I'debug' -I'.' -I'../../../qt/mkspecs/win32-g++' -o debug/moc_InstanceManager.o debug/moc_InstanceManager.cpp
g++ -enable-stdcall-fixup -Wl,-enable-auto-import -Wl,-enable-runtime-pseudo-reloc -pg -mthreads -Wl -Wl,-subsystem,windows -o debug/ASgui.exe debug/main.o debug/MainWindow.o debug/StartupParams.o debug/InstanceManager.o debug/gdbmacros.o debug/moc_MainWindow.o debug/moc_InstanceManager.o  -L'c:/Qt/2010.05/qt/lib' -lmingw32 -lqtmaind -LC:\Qt\2010.05\epicsqt\ca_framework/plugins/release -lQCaPlugin -L/opt/fontconfig/lib -lQtNetworkd4 -lQtUiToolsd -lQtXmld4 -lQtGuid4 -lQtCored4
mingw32-make[1]: Leaving directory `C:/Qt/2010.05/epicsqt/applications/ASguiApp'
mingw32-make: Leaving directory `C:/Qt/2010.05/epicsqt/applications/ASguiApp'
debug/MainWindow.o: In function `MainWindow':
C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:52: undefined reference to `ContainerProfile::ContainerProfile()'
C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:52: undefined reference to `ContainerProfile::~ContainerProfile()'
C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:58: undefined reference to `ContainerProfile::ContainerProfile()'
C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:58: undefined reference to `ContainerProfile::~ContainerProfile()'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:74: undefined reference to `ContainerProfile::setupProfile(QObject*, QObject*, QObject*, QObject*, QString, QString, bool)'
debug/MainWindow.o: In function `~MainWindow':
C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:130: undefined reference to `ContainerProfile::releaseProfile()'
C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:116: undefined reference to `ContainerProfile::~ContainerProfile()'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:256: undefined reference to `ContainerProfile::getPath()'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:271: undefined reference to `ContainerProfile::getPath()'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:437: undefined reference to `ContainerProfile::addMacroSubstitutions(QString)'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:440: undefined reference to `ContainerProfile::removeMacroSubstitutions()'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:452: undefined reference to `ContainerProfile::addMacroSubstitutions(QString)'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:455: undefined reference to `ContainerProfile::removeMacroSubstitutions()'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:462: undefined reference to `ContainerProfile::addMacroSubstitutions(QString)'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:463: undefined reference to `ContainerProfile::getMacroSubstitutions()'
debug/MainWindow.o:C:\Qt\2010.05\epicsqt\applications\ASguiApp/src/MainWindow.cpp:465: undefined reference to `ContainerProfile::removeMacroSubstitutions()'
collect2: ld returned 1 exit status
mingw32-make[1]: *** [debug/ASgui.exe] Error 1
mingw32-make: *** [debug] Error 2
The process "C:/MinGW/bin/mingw32-make.exe" exited with code %2.
Error while building project ASgui (target: Desktop)
When executing build step 'Make'
Morgan Bradford, B.E., E.I.T.
Jr. Accelerator Physicist
Canadian Light Source Inc.
Phone: 306.657.3729
Email: [email protected]
Prev: RE: EpicsQt build errors for QCaDesignerPlugin Morgan Bradford
Next: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Atomtex radiation monitors Bryce Karnaghan
