1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Error vxi11 with Lecroy 760Zi
To: DENIS Jean-françois <[email protected]>, <[email protected]>
Date: Mon, 14 Feb 2011 14:06:17 -0600
What version of asyn are you using?  There were some recent fixes for vxi11.
From: [email protected] on behalf of DENIS Jean-françois
Sent: Mon 2/14/2011 4:14 AM
To: [email protected]
Subject: Error vxi11 with Lecroy 760Zi
Hello,
I want to control a Lecroy scope WavePro 760Zi with EPICS. This scope integrate a vxi11 server.
I don't know how to do it. Many solutions
I think to start the simplest solution is with ASYN and STREAM DEVICE, but I have problem.
My configuration is:
st.cmd => vxi11Configure("TCP_SCOPE","132.166.33.202",1,0.0,"inst0",0,0)
Lecroy.db => record(waveform, "$(NOMOP):IDN")
         field(DTYP, "stream")
         field(INP, "@Lecroy_proto.db test TCP_SCOPE")
         field(NELM, "200")
         field(FTVL, "STRING")
lecroy_proto.db => test{
                        out "*IDN?";
                        in "%s";
Error =>
        iocLecroyLx > 2011/02/14 08:48:04.125 TCP_SCOPE vxi11 clientCall errno Permission denied clnt_stat 5
        2011/02/14 08:48:04.125 TCP_SCOPE vxiCreateIrqChannel (create_intr_chan): RPC: Timed out
        2011/02/14 08:48:04.125 TCP_SCOPE Warning -- SRQ not operational.
        2011/02/14 08:48:08.126 TCP_SCOPE vxi11 clientCall errno Success clnt_stat 5
        TCP_SCOPE vxiSrqEnable RPC error : RPC: Timed out
        2011/02/14 08:48:08.126 TCP_SCOPE asynGpib:pollAddr srqEnable
        2011/02/14 08:48:12.126 TCP_SCOPE vxi11 clientIoCall errno Success clnt_stat 5
        2011/02/14 08:48:12.126 TCP_SCOPE Lecoy:IDN: asynError in write: TCP_SCOPE RPC failed
I don't understand why...
Another solution is to install a EPICS base on the scope (windows 7), and use their library ActiveDSO. Is it a good idea?
Thanks.
Jean-François DENIS
CEA Saclay
RE : Error vxi11 with Lecroy 760Zi DENIS Jean-françois
Prev: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Andrew Johnson
Next: RE: USB4000 Geng, Zheqiao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Error vxi11 with Lecroy 760Zi DENIS Jean-françois
Next: RE : Error vxi11 with Lecroy 760Zi DENIS Jean-françois
