Title: RE : Error vxi11 with Lecroy 760Zi
I use the last version of ASYN.
This scope integrates also the VICP protocol. But when I use drvAsynIPPortConfigure("TCP_SCOPE","132.166.33.202:1861",0,0,0), nothing happens. I have not sure about the PORT. They use this PORT to communicate with their LECROY soft.
thanks,
Jean-François
-------- Message d'origine--------
De: Mark Rivers [mailto:[email protected]]
Date: lun. 14/02/2011 21:06
À: DENIS Jean-françois; [email protected]
Objet : RE: Error vxi11 with Lecroy 760Zi
What version of asyn are you using? There were some recent fixes for vxi11.
From: [email protected] on behalf of DENIS Jean-françois
Sent: Mon 2/14/2011 4:14 AM
To: [email protected]
Subject: Error vxi11 with Lecroy 760Zi
Hello,
I want to control a Lecroy scope WavePro 760Zi with EPICS. This scope integrate a vxi11 server.
I don't know how to do it. Many solutions
I think to start the simplest solution is with ASYN and STREAM DEVICE, but I have problem.
My configuration is:
st.cmd => vxi11Configure("TCP_SCOPE","132.166.33.202",1,0.0,"inst0",0,0)
Lecroy.db => record(waveform, "$(NOMOP):IDN")
field(DTYP, "stream")
field(INP, "@Lecroy_proto.db test TCP_SCOPE")
field(NELM, "200")
field(FTVL, "STRING")
lecroy_proto.db => test{
out "*IDN?";
in "%s";
Error =>
iocLecroyLx > 2011/02/14 08:48:04.125 TCP_SCOPE vxi11 clientCall errno Permission denied clnt_stat 5
2011/02/14 08:48:04.125 TCP_SCOPE vxiCreateIrqChannel (create_intr_chan): RPC: Timed out
2011/02/14 08:48:04.125 TCP_SCOPE Warning -- SRQ not operational.
2011/02/14 08:48:08.126 TCP_SCOPE vxi11 clientCall errno Success clnt_stat 5
TCP_SCOPE vxiSrqEnable RPC error : RPC: Timed out
2011/02/14 08:48:08.126 TCP_SCOPE asynGpib:pollAddr srqEnable
2011/02/14 08:48:12.126 TCP_SCOPE vxi11 clientIoCall errno Success clnt_stat 5
2011/02/14 08:48:12.126 TCP_SCOPE Lecoy:IDN: asynError in write: TCP_SCOPE RPC failed
I don't understand why...
Another solution is to install a EPICS base on the scope (windows 7), and use their library ActiveDSO. Is it a good idea?
Thanks.
Jean-François DENIS
CEA Saclay
- Error vxi11 with Lecroy 760Zi DENIS Jean-françois
- RE: Error vxi11 with Lecroy 760Zi Mark Rivers
no envPaths in application of base 3.14.11 Mi Qingru
RE: USB4000 David Beauregard
<2011>
2025
2026
Re: Error vxi11 with Lecroy 760Zi Peter . Mueller
<2011>
2025
2026
