1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Config for 2 Ethernet Adapters
To: [email protected]
Date: Tue, 15 Feb 2011 10:08:04 -0600
On Tuesday 15 February 2011 09:52:37 Paul Sichta wrote:
> Look in the CA Reference Manual for your release of EPICS.  I think
> you need to specify EPICS_CAS_INTF_ADDR_LIST .
Actually that variable has no effect on the IOC server, it only applies to the
CAS which is not (yet) used by the IOC code.
> On Tue, Feb 15, 2011 at 10:33,  <[email protected]> wrote:
> > I now need to take the legacy data from one network and make available on
> > another network via EPICS.  I have a Linux PC with 2 ethernet adapters,
> > eth0 the legacy control system, eth1 the EPICS control system.  The IOC
> > runs on this machine except I cannot see the EPICS PVs via other machines
> > on the eth1 network.
> > I'm guessing that the EPICS IOC is binding to eth0 by default and
> > expecting to serve data to this network?
> > How do I configure EPICS to bind to eth1 rather than to eth0, is this
> > possible?
The IOC server binds to all the interfaces it can see; there's actually no way
to change that with the current code.  I wonder whether your problem is
actually that the machines do not have the same subnet mask settings, and
hence their broadcast addresses are different?  On Unix systems 'ifconfig -a'
will print the broadcast address; you need to make sure that all systems are
using the same address.
The output from running 'casr 1' from the IOC shell may also give some hints.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
RE: EPICS Config for 2 Ethernet Adapters graham.cox
RE: EPICS Config for 2 Ethernet Adapters Jeff Hill
Re: EPICS Config for 2 Ethernet Adapters Paul Sichta
Prev: Re: EPICS Config for 2 Ethernet Adapters Paul Sichta
Next: RE: EPICS Config for 2 Ethernet Adapters graham.cox
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
