> Actually that variable has no effect on the IOC server, it only applies to
> the CAS which is not (yet) used by the IOC code.
The R3.15 CA server will support this functionality (in the IOC).
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Andrew Johnson
> Sent: Tuesday, February 15, 2011 9:08 AM
> To: [email protected]
> Subject: Re: EPICS Config for 2 Ethernet Adapters
> On Tuesday 15 February 2011 09:52:37 Paul Sichta wrote:
> > Look in the CA Reference Manual for your release of EPICS. I think
> > you need to specify EPICS_CAS_INTF_ADDR_LIST .
> the
> > On Tue, Feb 15, 2011 at 10:33, <[email protected]> wrote:
> > > I now need to take the legacy data from one network and make available
> on
> > > another network via EPICS. I have a Linux PC with 2 ethernet
> adapters,
> > > eth0 the legacy control system, eth1 the EPICS control system. The
> IOC
> > > runs on this machine except I cannot see the EPICS PVs via other
> machines
> > > on the eth1 network.
> > > I'm guessing that the EPICS IOC is binding to eth0 by default and
> > > expecting to serve data to this network?
> > > How do I configure EPICS to bind to eth1 rather than to eth0, is this
> > > possible?
> The IOC server binds to all the interfaces it can see; there's actually no
> way
> to change that with the current code. I wonder whether your problem is
> actually that the machines do not have the same subnet mask settings, and
> hence their broadcast addresses are different? On Unix systems 'ifconfig
> -a'
> will print the broadcast address; you need to make sure that all systems
> are
> using the same address.
> The output from running 'casr 1' from the IOC shell may also give some
> hints.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it. If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence. -- Bertrand Russell
- EPICS Config for 2 Ethernet Adapters graham.cox
- Re: EPICS Config for 2 Ethernet Adapters Paul Sichta
- Re: EPICS Config for 2 Ethernet Adapters Andrew Johnson
RE: soft ioc runs into fatal exception (base-3.14.12) Jeff Hill
<2011>
2025
2026
RE: EPICS Config for 2 Ethernet Adapters Jeff Hill
Arcturus uCDimm + TFTP John Dobbins
<2011>
2025
2026
