1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Arcturus uCDimm + TFTP
To: John Dobbins <[email protected]>
Cc: Eric Norum <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 15 Feb 2011 19:27:05 -0600
this is what i do as well. the initial download is a few minutes, but after
that it's never a problem over epics (i.e. flashburner application).
----- Original Message -----
Date: Tuesday, February 15, 2011 7:00 pm
To: Eric Norum <[email protected]>
> On 2/15/2011 4:13 PM, Eric Norum wrote:
>  > The problem is that the network stack provided by the uCDIMM
> bootstrap has a *very* small receive queue.    If you have any
> significant broadcast traffic on the network segment you'll start
> losing TFTP packets resulting in massive slowdowns.
>  > Possible workarounds:
>  > 1) Burn your first application into the ColdFire using TFTP on a
> quiet network segment -- I did this by connecting the ColdFire
> directly to my laptop -- with only two device on the network the TFTP
> transfers run very fast.
>  That is just what I did to get around this.
>  > 2) From then on use the EPICS flash memory driver to update your
> application.  The RTEMS network stack is much more robust and doesn't
> drop packets so easily.
>  I don't know about this EPICS flash memory driver. Is there something
> I
>  should have read?
>  Thanks,
>  John Dobbins
>  > What's really annoying is that the bad behaviour could be fixed
> with a small change in the bootstrap code -- once TFTP has begun, turn
> off reception of broadcast packets in the network hardware then turn
> reception back on when the TFTP command is terminated.   This would
> completely fix the problem while still allowing RARP/etc. to continue
> to work.   I suggested this to Arcturus several times, but they
> clearly haven't fixed things yet.
>  > On Feb 15, 2011, at 1:01 PM, John Dobbins wrote:
>  >> Hello All,
>  >> I have just built EPICS base and an example IOC for an
> RTEMS-uC5252 target (EPICS R3.14.11, RTEMS 3.9.3), which I can say
> went swimmingly well. However tftp problems are sucking all the fun
> out of it. The Arcturus uCDimm comes with a TFTP server which I am
> using with a 255.255.0.0 netmask. File transfer takes forever and
> usually ends in a time-out error. We have some evidence that things
> work much better on a subnet with a 255.255.255.0 mask. Can anyone
> shed light on any of this?
>  >> Regards,
>  >> John Dobbins
>  >> Cornell University
Arcturus uCDimm + TFTP John Dobbins
Re: Arcturus uCDimm + TFTP Eric Norum
Re: Arcturus uCDimm + TFTP John Dobbins
Prev: Re: Arcturus uCDimm + TFTP John Dobbins
Next: Re: no envPaths in application of base 3.14.11 Mi Qingru
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Arcturus uCDimm + TFTP Eric Norum
