1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Arcturus uCDimm + TFTP
To: John Dobbins <[email protected]>
Date: Tue, 15 Feb 2011 19:29:23 -0800
On Feb 15, 2011, at 4:59 PM, John Dobbins wrote:
> On 2/15/2011 4:13 PM, Eric Norum wrote:
>> The problem is that the network stack provided by the uCDIMM bootstrap has a *very* small receive queue.    If you have any significant broadcast traffic on the network segment you'll start losing TFTP packets resulting in massive slowdowns.
>> Possible workarounds:
>> 1) Burn your first application into the ColdFire using TFTP on a quiet network segment -- I did this by connecting the ColdFire directly to my laptop -- with only two device on the network the TFTP transfers run very fast.
> That is just what I did to get around this.
>> 2) From then on use the EPICS flash memory driver to update your application.  The RTEMS network stack is much more robust and doesn't drop packets so easily.
> I don't know about this EPICS flash memory driver. Is there something I should have read?
You can get this support from
	http://www.aps.anl.gov/epics/modules/instrument/mcf5282/index.html
>From the Description section of this support module:
The mcf5282 module contains drivers for the RTEMS-uC5282 target (ColdFire MCF5282 uCDIMM) including the queued analog to digital converter, the I2C interface, the bootstrap flash memory, I/O ports GPTA/B, and the CPU load. It also provides support for flash memory connected through an external FPGA, and FPGA configuration flash memory.
Eric Norum
[email protected]
Arcturus uCDimm + TFTP John Dobbins
Re: Arcturus uCDimm + TFTP Eric Norum
Re: Arcturus uCDimm + TFTP John Dobbins
Prev: Re: no envPaths in application of base 3.14.11 Mi Qingru
Next: Re: no envPaths in application of base 3.14.11 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Arcturus uCDimm + TFTP David Kline
Next: Re: Arcturus uCDimm + TFTP Nicholas P. DiMonte
