On 16.02.2011 02:35 Mi Qingru wrote:
CROSS_COMPILE_TARGET_ARCHS in base 3.14.11 may be wrong. I set it to "linux-x86".
As I set it to "linux-386", envPaths is generated in myapps/iocBoot/iocmyapps by make.
Whatever CROSS_COMPILE_TARGET_ARCHS is set to in base 3.14.8.2, envPaths will be generated.
I think the difference is in the file RULES.ioc .
Things I noticed:
The name of that variable is CROSS_COMPILER_TARGET_ARCHS (with an R at the end of the second part).
If you look at the list of supported cross-compiler architectures (e.g in BASE/configure/CONFIG_SITE), you will find that "linux-x86" is *not* a
supported cross-compiler architecture.
Nevertheless, "linux-x86" *is* a supported host architecture. Compiling the example app with an empty CROSS_COMPILER_TARGET_ARCHS and selecting
"linux-x86" as the IOC architecture does create the envPaths file correctly.
~Ralph
- no envPaths in application of base 3.14.11 Mi Qingru
- Re: no envPaths in application of base 3.14.11 Andrew Johnson
- Re: no envPaths in application of base 3.14.11 Mi Qingru
Re: Arcturus uCDimm + TFTP Eric Norum
Re: soft ioc runs into fatal exception (base-3.14.12) Carsten Winkler
<2011>
2025
2026
EPICS Config for 2 Ethernet Adapters graham.cox
<2011>
2025
2026
