1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: cygwin and DOS caget, caput running slow at end due to ca_context_destroy(), option to speed up execution?
To: "'Jay Steele'" <[email protected]>, <[email protected]>
Date: Wed, 16 Feb 2011 18:01:57 -0700
Jay,
I am on windows 7, but have used EPICS also on vista and 2000 w/o seeing such delays, but I use only
win32-x86 and win32-x86-mingw.
This might be an issue with cygwin-x86 (POSIX emulation on windows) versus win32-x86 or win32-x86-mingw (both native ports). If we are certain that it is waiting around in epicsThreadPrivateGet, which is typically expected to be a very fast and efficient call, then perhaps that is further evidence of something fishy in cygwin.
However, sometimes the debuggers are confused about where a blocking thread is actually parked. Another likely place is lingering in the socket close function. In my experience, the MS debugger can be habitually confused about where a thread is when it is parked in the winsock dll.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
From: [email protected] [mailto:[email protected]] On Behalf Of Jay Steele
Sent: Wednesday, February 16, 2011 4:07 PM
To: [email protected]
Hi Mark and Jeff
    Are you guys running Windows XP? My results on my Windows XP computer are different than yours for some reason. I measure about 5 seconds to run caget and caput. Here’s more information.
1.       No significant delay using MEDM GUI CA client on the same Windows XP computer to get or modify PV values on VxWorks IOC.
2.       For caget and caput, 5 second delay occurs inside function epicsThreadPrivateGet called from ca_context_destroy to access PV records on VxWorks IOC.
     I could speculate that there is something wrong with my EPICS makefiles and I’m not using the correct option somewhere for the cygwin build, but I get the similar results (delay ~5 seconds) with the pre-compiled Win32 Extension caget function. Could there be some Windows XP environmental variable or setting for handling threads that I need to set?
   When I add some print statements to track where the cygwin caget code is stalling, the code stalls for the 5 seconds at the last pthread_getspecific call inside epicsThreadPrivateGet. For some reason, the initial call to pthread_getspecific within epicsThreadPrivateGet function launches  a succession of calls to epicsThreadPrivateGet. I cannot find where this recursive logic is. Here’s the output. I get the same output when I run caget to access a PV record field from the softIOC running on the same Windows computer, but without the ~5 second delay.
Epics/base/src/ca/access.cpp - ca_context_destroy(), calling epicsThreadPrivateGet with id = 5382720
Epics/base/src/libCom/osi/os/posix/osdThread.c - epicsThreadPrivateGet(), id=5382720, calling assert
Epics/base/src/libCom/osi/os/posix/osdThread.c - epicsThreadPrivateGet(), calling pthread_getspecific
Epics/base/src/libCom/osi/os/posix/osdThread.c - epicsThreadPrivateGet(), id=5380552, calling assert
wait ~5 seconds . . .
Epics/base/src/ca/access.cpp - ca_context_destroy(), calling epicsThreadPrivateSet
Cheers,
Jay Steele
Sent: Wednesday, February 16, 2011 2:15 PM
To: Jay Steele; [email protected]
Hi Jay,
I don’t see this either, but I am using only win32-x86 and win32-x86-mingw on my windows machines. The cygwin posix emulation adds some additional layers around windows sockets to obtain posix compatibility.
Ø  the majority of the execution time (4-5 seconds) seems to be spent running the ca_context_destroy function
The ca_context_destroy will wait for the tcp circuit shutdown handshake to finish before returning. You can watch this with netstat or in GUIs like, for example on windows, tcpview. The GUI might update the tcp state machine changes more rapidly as they are occurring.
Jeff
[email protected]
Sent: Wednesday, February 16, 2011 1:00 PM
Subject: cygwin and DOS caget, caput running slow at end due to ca_context_destroy(), option to speed up execution?
Hi EPICS folks,
      I’m running caget and caput utility functions from cygwin and DOS on a Windows XP system to get and put data to a VxWorks IOC on the same subnet. I would like to know if there is some option to help speed up the execution of these utility functions. For both sets of utility functions, the majority of the execution time (4-5 seconds) seems to be spent running the ca_context_destroy function at the end. I don’t see this delay when running caget and caput functions to get and put data to a Soft IOC running on the same Windows XP computer. I don’t understand why there is such a delay just to clean up at the end.
     I’m using epics base v3-14-11 for cygwin and EPICS WIN32 Extensions Version 1.40 (Build 40) for DOS.
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
cygwin and DOS caget, caput running slow at end due to ca_context_destroy(), option to speed up execution? Jay Steele
RE: cygwin and DOS caget, caput running slow at end due to ca_context_destroy(), option to speed up execution? Jeff Hill
RE: cygwin and DOS caget, caput running slow at end due to ca_context_destroy(), option to speed up execution? Jay Steele
Prev: RE: cygwin and DOS caget, caput running slow at end due toca_context_destroy(), option to speed up execution? Mark Rivers
Next: Re: Error vxi11 with Lecroy 760Zi Peter . Mueller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: stream without asynPort emmanuel_mayssat
