Hello,
I am tryign to use a feature I have seen in stream protocols.
I would like to call iocsh function from a process variable.
ex:
when a bo record is set to 1, I would like to execute 'dbl' in the iocsh.
Q: is it possible to use stream without instanciating a asynPort ?
Q: is there another SIMPLE way to do this other than with stream ?
Q: apropos is it possible in stream to pass the value of the PV in exec lines?
ex: exec "dbpr mbboPV <valueOfMbboPV>" ;
Emmanuel
- Re: stream without asynPort Eric Norum
- Re: stream without asynPort Rod Nussbaumer
- Re: stream without asynPort Dirk Zimoch
Re: Error vxi11 with Lecroy 760Zi Peter . Mueller
<2011>
2025
2026
RE: cygwin and DOS caget, caput running slow at end due to ca_context_destroy(), option to speed up execution? Jeff Hill
<2011>
2025
2026
