1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stream without asynPort
To: EPICS tech-talk <[email protected]>
Date: Mon, 21 Feb 2011 15:02:40 +0100
Emmanuel,
Try the attched dummy interface. You have to add it to CONFIG_STREAM:
BUSSES += Dummy
It creates one global bus instance called "dummy".
I found a bug in exec parsing: In order to use %... in exec, you need to change StreamCode.cc:
In StreamCore::compileCommand() change
    if (strcmp(command, commandStr[exec_cmd]) == 0)
        buffer.append(exec_cmd);
        if (!protocol->compileString(buffer, args,
            NoFormat, this))
to
            PrintFormat, this))
Dirk
[email protected] wrote:
Hello,
I am tryign to use a feature I have seen in stream protocols.
I would like to call iocsh function from a process variable.
ex: when a bo record is set to 1, I would like to execute 'dbl' in the iocsh.
Q: is it possible to use stream without instanciating a asynPort ?
Q: is there another SIMPLE way to do this other than with stream ?
Q: apropos is it possible in stream to pass the value of the PV in exec lines?
   ex: exec "dbpr mbboPV <valueOfMbboPV>" ;
* StreamDevice Support                                         *
* (C) 2011 Dirk Zimoch ([email protected])                    *
* This is the interface to a "dummy" bus driver for            *
* StreamDevice. It does not provide any I/O functionality.     *
* If you do any changes in this file, you are not allowed to   *
* redistribute it any more. If there is a bug or a missing     *
* feature, send me an email and/or your patch. If I accept     *
* your changes, they will go to the next release.              *
* DISCLAIMER: If this software breaks something or harms       *
* someone, it's your problem.                                  *
#include "StreamBusInterface.h"
#include "StreamError.h"
#include "StreamBuffer.h"
// This is a non-blocking bus interface for debugging purpose.
// Normally, a bus interface will use blocking I/O and thus require
// a separate thread.
class DummyInterface : StreamBusInterface
    DummyInterface(Client* client);
    // StreamBusInterface methods
    bool lockRequest(unsigned long lockTimeout_ms);
    bool unlock();
protected:
    ~DummyInterface();
public:
    // static creator method
    static StreamBusInterface* getBusInterface(Client* client,
        const char* busname, int addr, const char* param);
RegisterStreamBusInterface(DummyInterface);
DummyInterface::
DummyInterface(Client* client) : StreamBusInterface(client)
    // Nothing to do
DummyInterface::
~DummyInterface()
    // Nothing to do
StreamBusInterface* DummyInterface::
    const char* busname, int addr, const char*)
    if (strcmp(busname, "dummy") == 0)
        DummyInterface* interface = new DummyInterface(client);
        return interface;
    return NULL;
bool DummyInterface::
    return false;
unlock()
    return false;
stream without asynPort emmanuel_mayssat
Prev: RE: Epics C# Library Bertrand Alain
Next: Re: Make target_arch only ... doesn't seem to work on 3.14.11 Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: stream without asynPort Rod Nussbaumer
Next: Fwd: Re: GigE cameras stops Bruce Hill
