1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Epics C# Library
To: "Morozov, Petr" <[email protected]>, <[email protected]>
Date: Mon, 21 Feb 2011 14:08:37 +0100
Indeed this is a bug of the library as we never really tested to
configure the channel list via the code itself.
I would suggest you to use the app.config file and define:
<configuration>
<appSettings>
<add key="e#ServerList" value="yourserver:yourport"/>
</appSettings>
</configutation>
we do support the following configuration settings:
    <add key="e#GetTimeout" value="5000"/>
    <add key="e#ServerList" value="sls-cagw.psi.ch:5062"/>
    <add key="e#ConnectTimeout" value="5000"/>
    <add key="e#channelSearchInterval" value="100"/>
    <add key="e#channelSearchMaxPackageSize" value="300"/>
    <add key="e#TCPMaxSendSize" value="4096"/>
Sincerly,
Alain Bertrand
-----Original Message-----
[mailto:[email protected]] On Behalf Of Morozov, Petr
Sent: Monday, February 21, 2011 12:45 PM
To: [email protected]
Subject: Epics C# Library
Hello,
I'd like to use EPICS under windows for our project at DESY (Hamburg,
Germany).
I have downloaded EpicsLibrary.dll version 1.2.0.0 and try to use that
under VB.NET 2008.
Simple example has written and I get the error message "Index was
outside the bounds of the array."
You can see the picture in attachment (how it looks like).
What is wrong?
Best regards,
Petr
Vorname Name                Deutsches Elektronen Synchrotron (Abteilung)
phone:  +49-40-8998-2866                              Notkestr. 85
fax:    +49-40-8994-2866                                   22607 Hamburg
e-mail: [email protected]                  Germany
Epics C# Library Morozov, Petr
Prev: Epics C# Library Morozov, Petr
Next: Re: stream without asynPort Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: ITER CODAC Core System Vs 2.0 released Di Maio Franck
