1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Make target_arch only ... doesn't seem to work on 3.14.11
To: EPICS tech-talk <[email protected]>
Date: Mon, 21 Feb 2011 09:39:41 -0600
The following lines will force a Makefile to build the abcd LIBRARY only for the linux-armv4tl arch.
LIBRARY_linux-armv4tl = abcd
LIBRARY = $(LIBRARY_$(T_A))
[email protected] wrote:
After investigation, I found that it works because I added:
ifeq (${T_A}, linux-x86_64)
exit:
endif
at the top of my Makefile...
Q: Is there a way to force the makefile to build only for one target arch (T_A)?
   i.e I want 'make linux-armv4tl' to be the default
Q: Again is there a way to build only one T_A without using the above trick?
E
On 15:30 Fri 18 Feb     , [email protected] wrote:
For some reason, it works now...
make linux-armv4tl
Note that make needs to be gnumake
On 15:12 Fri 18 Feb     , [email protected] wrote:
I have a 64bit machine which is used to compile arm binaries.
make linux-armv4tl
according to the manual should build only for the arm system.
But obviously it doesn't. First the compilation starts with the host architecture
(linux-x86_64 in my case)
Q: Is there a way to compile only for a specific T_A ?
Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
Prev: Re: stream without asynPort Dirk Zimoch
Next: RE: TFTP I/O Error Jim Eastman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
Next: Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
