> When these are set to produce verbose console output, it can be
difficult to turn them off by
> typing. Hooking them to EPICS records like multibit binaries could
make it really
> convenient.
That's already possible. You just connect an asyn record to that asyn
port. The asyn record has a nice medm screen which lets you turn the
mask bits on and off. Moreover, a single asyn record can be switched
between ports (and between asyn "addr" addresses) so you don't
necessarily need one asyn record for each port, a single asyn record per
IOC would be sufficient.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Rod Nussbaumer
Sent: Thursday, February 17, 2011 3:17 PM
To: EPICS tech-talk
Subject: Re: stream without asynPort
[email protected] wrote:
> Hello,
> Q: apropos is it possible in stream to pass the value of the PV in
exec lines?
> ex: exec "dbpr mbboPV<valueOfMbboPV>" ;
This is something I would really like to see (and no, AFAIK it isn't
possible right now). An example of where this would be nice would be in
the setting of asynTrace masks. When these are set to produce verbose
console output, it can be difficult to turn them off by typing. Hooking
them to EPICS records like multibit binaries could make it really
convenient.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
- Re: stream without asynPort Rod Nussbaumer
- stream without asynPort emmanuel_mayssat
Re: EtherIP support for "GuardLogix" PLC ? David Dudley
<2011>
2025
2026
<2011>
2025
2026
