1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GigE cameras stops
To: Bruce Hill <[email protected]>
Cc: "Stoffel, Pavel" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 17 Feb 2011 15:48:25 -0800
As you mentioned, that error appears when there's a signal handler being run while a system call is active.   It appears that this message is coming from:
inBufClient::fillCondition
casDGIntfIO::osdRecv ( char * pBufIn, bufSizeT size, // X aCC 361
    fillParameter parm, bufSizeT & actualSize, caNetAddr & fromOut )
    int status;
    osiSocklen_t addrSize;
    sockaddr addr;
    SOCKET sockThisTime;
    if ( parm == fpUseBroadcastInterface ) {
        sockThisTime = this->bcastRecvSock;
    else {
        sockThisTime = this->sock;
    addrSize = ( osiSocklen_t ) sizeof ( addr );
    status = recvfrom ( sockThisTime, pBufIn, size, 0,
                       &addr, &addrSize );
    if ( status <= 0 ) {
        if ( status < 0 ) {
            if ( SOCKERRNO != SOCK_EWOULDBLOCK ) {
                char sockErrBuf[64];
                epicsSocketConvertErrnoToString ( sockErrBuf, sizeof ( sockErrBuf ) );
                errlogPrintf ( "CAS: UDP recv error was \"%s\"\n", sockErrBuf );
        return casFillNone;
Jeff -- Is that SOCK_EWOULDBLOCK actually supposed to be SOCK_EINTR?  There's similar looking code in rsrv/cast_server.c:cast_server(void *pParm) that has
SOCK_EINTR.
IMHO code that uses signals to get things done is inherently evil.....
On Feb 17, 2011, at 3:31 PM, Bruce Hill wrote:
> We're having a problem with 'CAS: UDP recv errors" that's causing
> our GigE camera IOC's to stop updating images overnight.
> We're running EPICS 3.14.9, asyn R4.10.1, and areaDetector R1-2.
> When the images stop, we get these errors on our console:
> 17_14:39:08:CAS: UDP recv error (errno=Interrupted system call)
> 17_14:39:09:CAS: UDP recv error (errno=Interrupted system call)
> Googling "Interrupted system call" seems to indicated that repeating the
> system call, in this case, recv_from, may be needed.   It appears that the CA
> code is already doing that.
> I'm hoping that Jeff or Mark, or anyone, may have already seen this problem.
> We've been working on upgrading to 3.14.11 and newer modules, so if this
> problem has already been fixed we may just need to refocus our efforts on
> the upgrade.
> Thanks,
> - Bruce
Eric Norum
[email protected]
RE: GigE cameras stops Jeff Hill
Fwd: Re: GigE cameras stops Bruce Hill
Prev: Fwd: Re: GigE cameras stops Bruce Hill
Next: Re: Fwd: Re: GigE cameras stops Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: GigE cameras stops Jeff Hill
