On Monday 21 February 2011 11:59:42 Ralph Lange wrote:
> On 21.02.2011 18:45 Eric Norum wrote:
> > I wrote a simply asynOctet driver to do this. I've not yet packaged this
> > up for official release until I hear back from the folks testing this.
> > I'm not 100% sure that it's a good idea to allow commands to be run as
> > the result of record processing, but maybe there's a real need out there.
> Any subroutine record can execute commands in the context of record
> processing. Where's the big difference?
I think the word "command" implies the distinction. Many of the older IOC
test and debugging commands were coded with the assumption that they would be
run from the vxWorks shell, i.e. they're running in a very high priority
thread and won't normally be preempted by record processing, so they maybe
don't do as much locking as they should (indeed there may even be locks
missing from dbBase that would be needed to make them completely reliable and
thread-safe when used in that way, but adding such locks could adversely
affect the performance of the IOC).
I suspect that the 'dbl' command should be safe to run from record processing
since we don't support the ability to add or delete records at run-time, but
commands like 'scanppl' or 'dbior' might have subtle interactions that could
cause deadlocks, crashes or just wrong results in some circustances. I
haven't examined any source code in writing this response so I could be wrong
about my specific examples, but if anyone is going to rely on the ability to
run these kinds of commands from record processing they should do their own
due diligence about them first.
There's also the issue of blocking which Eric just brought up; if the command
takes a long time to run it could prevent other real-time operations from
operating normally.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- Re: [Fwd: Re: stream without asynPort] Dirk Zimoch
- [Fwd: Re: stream without asynPort] Dirk Zimoch
- Re: [Fwd: Re: stream without asynPort] Eric Norum
- Re: [Fwd: Re: stream without asynPort] Ralph Lange
<2011>
2025
2026
<2011>
2025
2026
