1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn interrupts... racing conditions?:w
To: EPICS tech-talk <[email protected]>
Date: Tue, 22 Feb 2011 16:32:56 -0800
I have an asyn port thread that generates SEVERAL I/O Interrupts.
Now the issue I have is that one of this interrupt update a waveform,
while another triggers the copy of the same waveform.
In code, the sequence is as follow:
1. interrupt to update waveform(compress)
2. interrupt to copy waveform
well, it seems that the copy of the waveform in (2) is the one
BEFORE the waveform is updated in (1)
Is this because the update of the waveform/compress is taking longer.
As a result, this record is not updated when (2) is executing?
It seems to be a race condition...
I guess a simple sleep could solve the problem, but just out of curiosity
is there a way to control processing of a record is completed before the waveform
copy is executedi/interrupt 2 is emitted?
Emmanuel
RE: asyn interrupts... racing conditions?:w Mark Rivers
Prev: Re: [Fwd: Re: stream without asynPort] Eric Norum
Next: RE: asyn interrupts... racing conditions?:w Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ITER CODAC Core System Vs 2.0 released Di Maio Franck
