1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Fwd: Re: stream without asynPort]
To: EPICS Tech Talk <[email protected]>
Date: Tue, 22 Feb 2011 13:08:33 -0800
In response to the interest shown in this I've asked Andrew to put the asynOctet IOCSH device support onto the EPICS module support page.
It provides a somewhat safer mechanism for running commands as the result of record processing in that it runs the command in a thread separate from the record processing thread.
There may very well be race conditions introduced by running IOCSH commands in a context other than that of the interactive command sessions -- Caveat Emptor.
> Andrew Johnson wrote:
>> On Monday 21 February 2011 11:59:42 Ralph Lange wrote:
>>> On 21.02.2011 18:45 Eric Norum wrote:
>>>> I wrote a simple asynOctet driver to do this.  I've not yet packaged this
>>>> up for official release until I hear back from the folks testing this.
>>>> I'm not 100% sure that it's a good idea to allow commands to be run as
>>>> the result of record processing, but maybe there's a real need out there.
>>> Any subroutine record can execute commands in the context of record
>>> processing. Where's the big difference?
>> I think the word "command" implies the distinction.  Many of the older IOC test and debugging commands were coded with the assumption that they would be run from the vxWorks shell, i.e. they're running in a very high priority thread and won't normally be preempted by record processing, so they maybe don't do as much locking as they should (indeed there may even be locks missing from dbBase that would be needed to make them completely reliable and thread-safe when used in that way, but adding such locks could adversely affect the performance of the IOC).
>> I suspect that the 'dbl' command should be safe to run from record processing since we don't support the ability to add or delete records at run-time, but commands like 'scanppl' or 'dbior' might have subtle interactions that could cause deadlocks, crashes or just wrong results in some circustances.  I haven't examined any source code in writing this response so I could be wrong about my specific examples, but if anyone is going to rely on the ability to run these kinds of commands from record processing they should do their own due diligence about them first.
>> There's also the issue of blocking which Eric just brought up; if the command takes a long time to run it could prevent other real-time operations from operating normally.
>> - Andrew
Eric Norum
[email protected]
[Fwd: Re: stream without asynPort] Dirk Zimoch
Re: [Fwd: Re: stream without asynPort] Eric Norum
Re: [Fwd: Re: stream without asynPort] Ralph Lange
Re: [Fwd: Re: stream without asynPort] Andrew Johnson
Re: [Fwd: Re: stream without asynPort] Dirk Zimoch
Prev: ITER CODAC Core System Vs 2.0 released Di Maio Franck
Next: asyn interrupts... racing conditions?:w emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Fwd: Re: stream without asynPort] Dirk Zimoch
Next: Epics C# Library Morozov, Petr
