> It might also help to know if one was cross-compiled and by what
> host architecture. (I think there's a bug in the seq 2.0.12 SNL
> compiler when cross-compiling from a 64-bit host architecture to
> a 32-bit target architecture. I think the SNL compiler may
> generate certain numbers that are too big for the 32-bit target
> architecture. But I haven't had time to investigate and create
> a simple test case.)
Thank you very much for the information.
So far, we have not used 64-bit architecture for the cross-compilation.
But sooner or later, we will use a 64-bit host machine.
I'll keep it in mind.
Jun-ichi
----- Original Message -----
> On 2/25/11 3:37 PM, [email protected] wrote:
> > At first I wanted to suggest you check with the latest stable
sequencer version
> > (2.0.12) but this now really looks like CA (or your setup of it) is
at fault.
> > The fact that you have the -c option for caput means the client side
uses
> > EPICS base 3.14.12, right? What EPICS version runs on the IOC?
> FYI, the caput from EPICS Base 3.14.11 has the -c option too. I
> think it might even be in 3.14.10.
> > Values shortened to a multiple of 256, this sounds like a byte order
problem.
> > Knowing the exact type and version of the OS used on both client and
server
> > side might help to solve this.
> Lewis
> J. Lewis Muir
> Software Engineer
> IMCA-CAT
- About pvPut dafault behavior jun-ichi.odagiri
- Re: About pvPut dafault behavior Benjamin Franksen
- Re: About pvPut dafault behavior jun-ichi.odagiri
- Re: About pvPut dafault behavior benjamin . franksen
- Re: About pvPut dafault behavior J. Lewis Muir
<2011>
2025
2026
<2011>
2025
2026
