1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: About pvPut dafault behavior
To: <[email protected]>
Cc: [email protected]
Date: Mon, 28 Feb 2011 09:38:06 +0900
> At first I wanted to suggest you check with the latest stable
sequencer version
> (2.0.12) but this now really looks like CA (or your setup of it) is at
fault.
> The fact that you have the -c option for caput means the client side
uses
> EPICS base 3.14.12, right? What EPICS version runs on the IOC?
At first, we observed the problem with the following configuration.
The sncseq-2.0.12 was executed on a PowerPC (MPC8347E)-based IOC cross-
compiled by a 32-bit linux-x86 host architecture (CentOS 4.6). Base-3.14.
9
was used for the IOC.
The other IOC which held the soft record was PowerPC 440-based (Virtex5)
cross-compiled by a 32-bit linux-x86 architecture (WindRiver Workbech 2.
0).
Base-3.14.9 was used for the IOC.
Then, I found the "values shortened to a multiple of 256"-problem when
SYNC/
ASYNC-option was specified. I guessed that the cause was in miss-match
of
versions between sequencer and the base. So, I down-graded the sequencer
from
sncseq-2.0.12 to snc-2.0.11. But the result was the same.
Next, I executed seq-2.0.11 with base-3.14.9 on a linux-x86-based IOC
self-
compiled by CentOS 4.6. The soft record was placed on the PowerPC (
MPC8347E)-
based IOC running base-3.14.9. Then, I found that only a value of zero
can be
put to the soft record when SYNC-potion was specified.
> Values shortened to a multiple of 256, this sounds like a byte order
problem.
> Knowing the exact type and version of the OS used on both client and
server
> side might help to solve this.
I think it is the most probable cause of the problem. I'll investigate
the
problem keeping your suggestions in mind.
Thanks a lot for your advice.
Jun-ichi
----- Original Message -----
> Am Freitag 25 Februar 2011, um 15:01:32 schrieben Sie:
> > Now, I have to bring up a problem I'm facing on pvPut.
> > The attached files are a simple .stt program that repeatedly puts
> > a value into a PV, and a .db file including the PV (a soft longout
> > record with its all fields initialized with their default values).
> > If the .stt progrm runs on an IOC where the soft record resides,
> > it works just fine for all of the following three cases:
> > 1. pvPut(var)
> > 2. pvPut(var, SYNC)
> > 3. pvPut(var, ASYNC).
> > However, if the .stt program runs on an IOC to put a value into
> > the soft record placed on another IOC, only pvPut(var) works fine.
> > pvPut(var, SYNC) and pvPut(var, ASYNC) behave strangely. It's very
> > hard to explain in short sentences since it varies from case to
> > case.
> > For example, the value actually put into the record is shortened
> > to a multiple of 256 that is mostly close to the value the .stt
> > program tried to put... or ... always zero...
> > At any rate, pvPut(var, SYNC) and pvPut(var, ASYNC) shows exactly
> > the same strange befavior in the situation.
> > I found that "caput -c" also does not work in that situation. So,
> > I guess this problem might be related with Channel Access as the
> > underlying message system.
sequencer version
fault.
uses
problem.
server
> Cheers
> Ben
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
Forschungszentren e.V
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
> Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.
c. Wolfgang Eberhardt, Dr. Ulrich Breuer
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
About pvPut dafault behavior jun-ichi.odagiri
Re: About pvPut dafault behavior Benjamin Franksen
Re: About pvPut dafault behavior jun-ichi.odagiri
Re: About pvPut dafault behavior benjamin . franksen
Prev: Re: About pvPut dafault behavior jun-ichi.odagiri
Next: Re: About pvPut dafault behavior jun-ichi.odagiri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
