1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: About pvPut dafault behavior
To: "Mark Rivers" <[email protected]>
Cc: [email protected]
Date: Mon, 28 Feb 2011 08:24:28 +0900
> Is the other IOC behind a PV gateway?
No. All IOCs are on a single network and no PV gateway is included.
Jun-ichi
----- Original Message -----
> -----Original Message-----
> From: [email protected] on behalf of jun-ichi.odagiri@kek.
jp
> Sent: Fri 2/25/2011 8:01 AM
> To: Benjamin Franksen
> Dear Ben;
> I'd like to thank you for your crystal clear answer.
> I understood the differences between no-option case, SYNC-option
> case and ASYNC-option case.
> Now, I have to bring up a problem I'm facing on pvPut.
> The attached files are a simple .stt program that repeatedly puts
> a value into a PV, and a .db file including the PV (a soft longout
> record with its all fields initialized with their default values).
> If the .stt progrm runs on an IOC where the soft record resides,
> it works just fine for all of the following three cases:
> 1. pvPut(var)
> 2. pvPut(var, SYNC)
> 3. pvPut(var, ASYNC).
> However, if the .stt program runs on an IOC to put a value into
> the soft record placed on another IOC, only pvPut(var) works fine.
> pvPut(var, SYNC) and pvPut(var, ASYNC) behave strangely. It's very
> hard to explain in short sentences since it varies from case to
> case.
> For example, the value actually put into the record is shortened
> to a multiple of 256 that is mostly close to the value the .stt
> program tried to put... or ... always zero...
> At any rate, pvPut(var, SYNC) and pvPut(var, ASYNC) shows exactly
> the same strange befavior in the situation.
> I found that "caput -c" also does not work in that situation. So,
> I guess this problem might be related with Channel Access as the
> underlying message system.
> I appreciate it if you could give me any suggestions on what I
> can try to solve the problem.
> Thanks a lot in advance.
> Jun-ichi
> > On Friday, February 25, 2011, [email protected] wrote:
> > > Dear all;
> > > I'm looking into the following site to check if pvPut of seq-2.0.
11
> > > works synchronously or asynchronously (with NO compiler option and
> > > NO explicit SYNC/ASYNC option, just a pvPut(pvname) call).
> > > http://www-csr.bessy.de/control/SoftDist/sequencer/Manual.html
> > > In "Notes on Release 2.0 (Synchronous/asynchronous override on
gets
> and
> > > puts)",
> > > it says as follwos:
> > > "pvGet and pvPut both accept an optional SYNC or ASYNC argument
that,
> > > for pvGet, overrides the default as set using the -a option and,
for
> > > pvPut, overrides the default synchronous behavior."
> > > So, I thought pvPut(pvname) works synchronously. However, it say
in
> > > "Asynchronous Use of pvPut" as follows:
> > > "Normally the pvPut operation completes asynchronously. In the
past
> it
> > > has been the responsibility of the programmer to ensure that the
> > > operation completed (typically by monitoring other variables).
> However,
> > > the function pvPutComplete can now be used for this."
> > > So, I'm getting confused.
> > > Does pvPut(pvname) work synchronously, or asynchronously by
default?
> > > Sorry in advance if I'm bothering you all due to my poor ability
in
> > > reading English.
> > Not at all. You are pointing out a bug in the release notes: the
first
> > paragraph is wrong as stated; I am going to fix that. The default
> behaviour
> > for pvPut is definitely asynchronous, or, to put it more precisely,
> pvPut
> > sends the request off to the PV and does *not* wait for any
> confirmation (in
> > fact never requests it in the first place). In short: it is a fire
and
> > forget operation.
> > It may be clarifying to point out that for the pvPut operation, the
> > synchronous/asynchronous distinction is not enough to completely
> describe
> > the behaviour. There are actually three variants, one synchronous
and
> two
> > asynchronous:
> > * pvPut(var): fire and forget, no completion message is requested
> > * pvPut(var,SYNC): request completion message, block state set (
thread)
> >   until it arrives (or timeout occurs)
> > * pvPut(var,ASYNC): request completion message but do not block
state
> >   set; instead user code can call pvPutComplete to find out if
> completion
> >   message has arrived
> > Note that pvPut is *not* affected by the +a or -a options given to
the
> snc
> > compiler. These options only change the default behaviour of pvGet.
> > You can find a more detailed description of the pvPut and pvGet (and
> all
> > other) commands in the online SNL reference at
> > http://www-csr.bessy.de/control/SoftDist/sequencer/Reference.html
> > HTH
> > Ben
> > ________________________________
> > Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> > Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V
> > Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
> stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
> > Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr.
h.
> c. Wolfgang Eberhardt, Dr. Ulrich Breuer
> > Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> > Postadresse:
> > Hahn-Meitner-Platz 1
> > D-14109 Berlin
> > http://www.helmholtz-berlin.de
About pvPut dafault behavior jun-ichi.odagiri
Re: About pvPut dafault behavior Benjamin Franksen
Re: About pvPut dafault behavior jun-ichi.odagiri
RE: About pvPut dafault behavior Mark Rivers
Prev: Re: About pvPut dafault behavior J. Lewis Muir
Next: Re: About pvPut dafault behavior jun-ichi.odagiri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: About pvPut dafault behavior Mark Rivers
Next: Re: About pvPut dafault behavior benjamin . franksen
