1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: About pvPut dafault behavior
To: <[email protected]>
Date: Mon, 28 Feb 2011 12:01:05 +0100
Hello Jun-ichi
On Monday, February 28, 2011, you wrote:
> Hi Ben and all;
> I found that pvPut(var, SYNC) works with base-3-14-11 and sncseq-2.0.12
> just fine for a combination of IOCs with different types of
> architectures.
> I expect pvPut(var, SYNC) works for other combinations of IOCs though I
> have not yet tested it.
Ok, so your problem was solved by moving from base-3.14.9 to base-3.14.11.
Could you also try 3.14.12? Also, could you verify that "caput -c" also
works as expected?
If the latest two versions of base work fine, we can probably feel safe
ignoring the problem, else further investigation is in order.
Cheers
Ben
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: About pvPut dafault behavior jun-ichi.odagiri
Re: About pvPut dafault behavior benjamin . franksen
Prev: Re: About pvPut dafault behavior jun-ichi.odagiri
Next: Re: Anyone working on PCO camera support? Brands Helge
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: About pvPut dafault behavior jun-ichi.odagiri
