Hello Ben;
> Ok, so your problem was solved by moving from base-3.14.9 to base-3.14.
11.
I guess so.
> Could you also try 3.14.12? Also, could you verify that "caput -c"
also
> works as expected?
I tested the simple .stt program to pvPut a value with SYNC-option to
a remote IOC with base-3.14.12 and sncseq-2.0.12. It also worked fine.
In addition, I found that "caput -c" also worked fine with both of the
combinations:
base-3-14-11 and sncseq-2.0.12
> If the latest two versions of base work fine, we can probably feel
safe
> ignoring the problem, else further investigation is in order.
I'm now feeling safe though I have to do further tests with a different
combination of IOC architectures.
Thanks a lot again!
Cheers
Jun-ichi
----- Original Message -----
> Hello Jun-ichi
> On Monday, February 28, 2011, you wrote:
> > Hi Ben and all;
> > I found that pvPut(var, SYNC) works with base-3-14-11 and sncseq-2.0.
12
> > just fine for a combination of IOCs with different types of
> > architectures.
> > I expect pvPut(var, SYNC) works for other combinations of IOCs
though I
> > have not yet tested it.
11.
also
> works as expected?
safe
> Cheers
> Ben
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
Forschungszentren e.V
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
> Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.
c. Wolfgang Eberhardt, Dr. Ulrich Breuer
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
- About pvPut dafault behavior jun-ichi.odagiri
- Re: About pvPut dafault behavior benjamin . franksen
- Re: About pvPut dafault behavior jun-ichi.odagiri
- Re: About pvPut dafault behavior Benjamin Franksen
edl2boy? james.rowland
Problem with Motor Record on RTEMS on MVME5500 Jim Eastman
<2011>
2025
2026
Does areadetector drvier support Procilica GE1650 CCD? Silver
<2011>
2025
2026
