1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with Motor Record on RTEMS on MVME5500
To: "EPICS Tech Talk" <[email protected]>
Date: Tue, 1 Mar 2011 08:07:27 -0800
Hi all,
So continuing to learn my way through all of this, I'm encountering a problem with using the motor record to control a MAXv. The basic setup: an MVME5500 running RTEMS 4.10 (with the bspExt code for the mvme5500), and I've tried both 3.14.11 and 3.14.12 versions of EPICS using version 6-5-2 of the motor record. Building and deploying the NoAsyn example app.
Here is my startup output:
Welcome to rtems-4.10.0(PowerPC/Generic (classic FPU)/mvme5500) on MVME5500-0163
Now BSP_mem_size = 0x1FE00000
Marvell GT64260B (Discovery I) hostbridge detected at bus0 slot0
BSP unlisted vendor, Bus0 Slot10 DeviceID 0x263388
TUNDRA PCI-VME bridge detected at bus1 slot0
Marvell GT64260B (Discovery I) hostbridge detected at bus8 slot0
BSP unlisted vendor, Bus8 Slot10 DeviceID 0x10088086
Universe II PCI-VME bridge detected at 0x82000000, IRQ 12
Universe Master Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
1:    0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
2:    0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
Universe Slave Ports:
0:    0x90000000 0x1FE00000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
Overriding main IRQ line PCI info with 76
Registering /dev/console as minor 0 (==/dev/ttyS0)
***** Initializing network *****
Startup.
Attaching MVME5500 1GHz NIC1
RTEMS-mvme5500 BSP Copyright (c) 2004,2005,2008, Brookhaven National Lab., Shuchen Kate Feng
***** Initializing NFS *****
Mount 10.40.30.108:/tftpboot/epics on /epics
RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
***** Starting EPICS application *****
#Startup script for loading and configuring an OMS MAXv controller.
< /epics/mvme5500/envPaths
epicsEnvSet("ARCH","RTEMS-mvme5500")
epicsEnvSet("IOC","iocNoAsyn")
dbLoadDatabase("/epics/mvme5500/dbd/motorRecord.dbd")
dbLoadDatabase("/epics/mvme5500/dbd/devOms.dbd")
dbLoadDatabase("/epics/mvme5500/dbd/NoAsyn.dbd")
NoAsyn_registerRecordDeviceDriver(pdbbase)
dbLoadTemplate("/epics/mvme5500/motor.substitutions")
MAXvSetup(1, 16, 0xF000, 190, 5, 10)
MAXvConfig(0, "AX LL PSO; AY LL PSO; AZ LL PSO; AT LL PSO; AU LH PSO; AV LH PSO; AR LH PSO; AS LH PSO;")
iocInit
Starting iocInit
## EPICS R3.14.12 $Date: Wed 2010-11-24 14:50:38 -0600$
## EPICS Base built Feb 25 2011
libbspExt - Warning: it seems that MCP support is not available on your CPU
                     or not implemented by your board. Address probing must
                     be performed in polling mode with interrupts disabled
Warning: bspExtMemProbe kills real-time performance.
         Your BSP does or can not use MCP exceptions - we
         must probe with INTERRUPTS DISABLED !!!
         use only during driver initialization
         clear the 'bspExtVerbosity' variable to silence this warning
Illegal field value PV: IOC:m1 motor_init_record_com(): card does not exist!
Illegal field value PV: IOC:m2 motor_init_record_com(): card does not exist!
Illegal field value PV: IOC:m3 motor_init_record_com(): card does not exist!
Illegal field value PV: IOC:m4 motor_init_record_com(): card does not exist!
Illegal field value PV: IOC:m5 motor_init_record_com(): card does not exist!
Illegal field value PV: IOC:m6 motor_init_record_com(): card does not exist!
Illegal field value PV: IOC:m7 motor_init_record_com(): card does not exist!
Illegal field value PV: IOC:m8 motor_init_record_com(): card does not exist!
Here's what my motor.substitutions file looks like:
file "/epics/mvme5500/db/basic_motor.db"
pattern
{P,     N,  M,        DTYP,        C,  S,  DESC,               EGU,      DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT,     PREM,  POST}
{IOC:,  1,  "m$(N)",  "OMS MAXv",  0,  0,  "motor axis $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  "AN LL",  "AF",  "AN"}
{IOC:,  2,  "m$(N)",  "OMS MAXv",  0,  1,  "motor axis $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  "AN LL",  "AF",  "AN"}
{IOC:,  3,  "m$(N)",  "OMS MAXv",  0,  2,  "motor axis $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  "AN LL",  "AF",  "AN"}
{IOC:,  4,  "m$(N)",  "OMS MAXv",  0,  3,  "motor axis $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  "AN LL",  "AF",  "AN"}
{IOC:,  5,  "m$(N)",  "OMS MAXv",  0,  4,  "motor axis $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  "AN LL",  "AF",  "AN"}
{IOC:,  6,  "m$(N)",  "OMS MAXv",  0,  5,  "motor axis $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  "AN LL",  "AF",  "AN"}
{IOC:,  7,  "m$(N)",  "OMS MAXv",  0,  6,  "motor axis $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  "AN LL",  "AF",  "AN"}
{IOC:,  8,  "m$(N)",  "OMS MAXv",  0,  7,  "motor axis $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  "AN LL",  "AF",  "AN"}
I'm not sure why I'm not able to communicate with the MAXv controller ( maybe it has something to do with the bspExt warnings? ). I hope that covers the relevant details. Any help or advice would be greatly appreciated. Thanks!
Jim Eastman
This e-mail and any attachment(s) are from Pro-Dex, Inc. and may contain information that is confidential or privileged. If you are not the intended recipient, do not read, copy or distribute the e-mail or any attachments. Instead, please notify the sender at the phone number indicated above and delete the e-mail and any attachments. Thank you.
Re: Problem with Motor Record on RTEMS on MVME5500 Kate Feng
Prev: Re: About pvPut dafault behavior jun-ichi.odagiri
Next: Re: Problem with Motor Record on RTEMS on MVME5500 Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: edl2boy? Chen, Xihui
