1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ca subscriptions, invalid pv
To: [email protected]
Date: Wed, 2 Mar 2011 14:45:19 -0800 (PST)
Two questions:
1. If a channel is connected or reconnects, and a call to
ca_create_subscription succeeds or has previously succeeded, is there
anything else that could go wrong on the ioc side that might cause the
channel not to be monitored (other than the channel disconnecting)? And if
so, is there a way to tell from the client side? Do I have to wait for the
event handler to be called before I can trust that everything is working?
2. How do you usually deal with setting a pv invalid if the data is being
put to it from an external program (ie, not device support) and that
program fails? Do you write device support for the ioc hosting the pv, and
use it to get the value and a status update from the program? Is there a
more preferred method?
Thank you,
Patrick
Re: ca subscriptions, invalid pv Andrew Johnson
RE: ca subscriptions, invalid pv Allison, Stephanie
RE: ca subscriptions, invalid pv Jeff Hill
Prev: Re: How to know if a PV is on a Soft IOC or not ? Dirk Zimoch
Next: Re: ca subscriptions, invalid pv Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to know if a PV is on a Soft IOC or not ? emmanuel_mayssat
