On 3/20/11 9:52 AM, Kevin Jordan wrote:
> HI
> I was trying to run virtual linac and I get the following error:
> Last login: Sun Mar 20 10:44:12 on ttys000
> Kevin-Jordans-iMac:~ kevin$ /Users/kevin/Documents/EPICS/vlinac/startMedm.command ; exit;
> dyld: Library not loaded: /sw/lib/libreadline.5.dylib
> Referenced from: /Users/kevin/Documents/EPICS/vlinac/lib/darwin-x86/libca.3.14.11.dylib
> Reason: image not found
> Referenced from: /Users/kevin/Documents/EPICS/vlinac/bin/darwin-x86/medm
> Trace/BPT trap
> logout
> How do I load this library?
> Thanks,
> Kevin
Hi, Kevin.
It looks like it can't find the readline library. This is
probably because it's not installed on your computer. Did you
search the Tech-Talk mailing list? I think the following thread
addresses your issue:
http://www.aps.anl.gov/epics/tech-talk/2010/msg01443.php
Andrew or vlinac maintainer: I think a binary package like this
should have readline bundled with it or should be built without
the readline support to eliminate this dependency.
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT
- Re: error 'Library not loaded' for virtual linac Andrew Johnson
- error 'Library not loaded' for virtual linac Kevin Jordan
some CAJ and JCA questions John Dobbins
<2011>
2025
2026
<2011>
2025
2026
