1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error 'Library not loaded' for virtual linac
To: [email protected]
Date: Mon, 21 Mar 2011 12:18:41 -0500
Hi Lewis,
On Sunday 20 March 2011 17:01:46 J. Lewis Muir wrote:
> Andrew or vlinac maintainer: I think a binary package like this
> should have readline bundled with it or should be built without
> the readline support to eliminate this dependency.
Distributing the readline library legally would require me to find and make
available a copy of the source code used to build that exact version of
readline, as well as to license the vlinac under the GPL, which as I have said
before isn't my call since it's not my code.
The existing package copies the necessary libraries from the common Base
builds here at APS, which are configured to use readline on Darwin and Linux.
Eliminating readline would require me to build special versions of Base for
the two Darwin targets before building the vlinac — not hard I admit, but it
adds another significant step to the packaging process.  I've added a copy of
Steve Lewis' instructions to the README file instead.
If you or anyone else wishes to provide a better built and packaged version of
the vlinac for Darwin I'd be happy to host or point to it.  I would also love
to see a few more down-loadable examples of other stand-alone IOC applications
that beginners could install to try out EPICS.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
error 'Library not loaded' for virtual linac Kevin Jordan
Re: error 'Library not loaded' for virtual linac J. Lewis Muir
Prev: some CAJ and JCA questions John Dobbins
Next: Breakpoint Table Error Steiner, Mathias
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: error 'Library not loaded' for virtual linac J. Lewis Muir
Next: some CAJ and JCA questions John Dobbins
