1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epicsqt first try
To: "[email protected]" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 22 Mar 2011 09:31:27 +1100
Hi Emmanuel
There is not much wrong with your code below, but I believe you always need to create widgets like QLabels (our EPICS flavor or otherwise) within a main window widget.
Also, the CA connection is not established automatically, you have to call the 'activate()' method once the widget is created.
Calling 'activate()' is a minor overhead that I would like to avoid for simple widgets that could otherwise just 'go' but allows for widgets that take multiple PVs and then require macro substitution to be applied to those PVs.
Below is your code with the following changes:
1) required: A QMainWindow is created to contain the QCaLabel widget
2) required: The QCaLabel::activate() method is called.
3) just for fun: The QLabel::setFrameShape() method is called to ensure something is visible even if the text displayed is a blank string.
4) required: The 'QWidget::show()' method is called for the QMainWindow rather than the QCaLabel
I hope this helps,
Andrew
#include <QApplication>
#include <QMainWindow>
#include <QCaLabel.h>
int main(int argc, char *argv[])
    QApplication a(argc, argv);
    QMainWindow* mainW = new QMainWindow;
    QCaLabel* label = new QCaLabel( "DMC2183:1:DscrptnSI", mainW );
    // Ensure the something of the label is visible, even if it contains no text, (just for testing)
    label->setFrameShape(QFrame::Box);
    // Establish CA connection
    // This does not happen automatically to allow PV name macro substitutions to be performed.
    // (Perhaps this should not be required when passing a PV on construction?)
    label->activate();
    mainW->show();
    return a.exec();
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Tuesday, 22 March 2011 8:46 AM
To: EPICS tech-talk
Subject: epicsqt first try
----- Forwarded message from [email protected] -----
Date: Wed, 16 Mar 2011 17:26:16 -0700
To: "Andrew Rhyder (epicsqt)" <[email protected]>,
Cc: Emmanuel Mayssat <[email protected]>
Andrew Rhyder,
I am testing your epicsqt package.
I may be interested in wrapping it in SIP so that your libraries can
be used in python (which i use heavily)
But before I do so, I am trying to test your Qt designer plugin.
First, I would like to use a simple QCaLabel object.
$ cat main.cpp
  QCaLabel label("DMC2183:1:DscrptnSI");
  label.show();
  return a.exec();
I have
$ caget DMC2183:1:DscrptnSI
DMC2183:1:DscrptnSI            OC:C50-C70-C90
I compile without any errors....
I start the program...
and I don't see anything ;-(
I assume that QCaLabel can be used to display the content of a string PV.  What am I doing wrong?
Emmanuel
----- End forwarded message -----
Emmanuel
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: epicsqt first try emmanuel_mayssat
Prev: epicsqt first try emmanuel_mayssat
Next: waveform transformation emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: epicsqt first try emmanuel_mayssat
